P0A08 error code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whodat, Sep 13, 2010.
  1. MAX2
    MAX2 Junior Member
    85
    Third Rock from the Sun
    A 12-volt battery is needed to start the hybrid system.
    After the sign “ready” lights up on the display, the hybrid converter supplies the car’s network with a voltage of 13-14 volts, which is used by the car’s systems and charges the 12-volt battery.
    Is the "ready" light on on your car?
  2. retirednongeek
    retirednongeek New Member
    Houston, TX
    Another bit of info. I Googled how to check the charging system, and came across a whole series of YouTube videos created by Professor John Kelly with the Weber Auto YouTube Channel, part of the Weber University. This one in particular is very helpful and answered several of my questions.
    The demonstration is using a 3rd generation Prius (2017), but the tests described would be similar for a 2nd generation (2004 to 2009).
    I don't yet have a multimeter capable of checking DC amps, but I will investigate getting (or borrowing) one of those.
    From the test just for battery voltage, I am definitely not getting any current to the 12V battery. Connecting my multimeter to the jump start contact under the hood and to ground, the meter reads about 12.5 volts whether the car is "OFF" or is "ON" and "READY".
    Now I need to check the DC Amps entering or leaving the 12V battery to determine if the DC to DC Converter is working properly.
    The only other possible cause I can think of would be if the fusible link block at the positive terminal of the 12V battery is blown. Checking the amps going to the fusible link block and then between the fusible link block and the battery positive terminal may be the test to determine what is wrong.
    #22 retirednongeek, Aug 20, 2024 at 9:36 AM
  3. retirednongeek
    Houston, TX
    Thanks for your reply, which i just saw after posting another update. Yes, the "Ready" light comes on.
  4. MAX2
    MAX2 Junior Member
    85
    After turning on the "ready", check the output voltage from the converter white wire connector (B) pin 1.(AMD)
    If there is a voltage of 13-14 volts on the converter, the wire to the fuse and relay box may fall off.
  5. retirednongeek
    Houston, TX
    Thanks for the additional option in diagnosing the output of the DC to DC Converter. Am I correct that this larger white wire with grey connector (single contact grey connector pointed straight back and below other grey connector) is buried deep in the engine compartment, near the left and near the bottom of the inverter/converter? And, in order to get the connector off and measure directly at the converter, will definitely have to do some disassembly. Let me ponder that ... trying to find a used inverter/converter nearby in case that is required in order to fix, so if that looks promising, then disassembly will be necessary anyway. Untitled-16.jpg
    #25 retirednongeek, Aug 21, 2024 at 7:23 AM
  6. MAX2
    MAX2 Junior Member
    85
    Look at the diagram.
    https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a09265.pdf
    The converter supplies voltage to the 12V system via the upper wire (AMD line). This voltage goes to the fuse and relay box.
    The lower wire from the battery S (It is located on the positive terminal of the 12V battery, a small fuse and a white wire) goes to the converter. This is the feedback line. The converter reads the voltage directly from the battery via this wire and, if necessary, adds a voltage delta to charge the 12V battery.
