Gen 3 vs Gen 4 water pump replacement
Discussion in 'Prius v Technical Discussion' started by Kpeeling, Aug 21, 2024 at 6:45 PM.
  1. Kpeeling
    Kpeeling Junior Member
    28
    South Central PA
    2017 Prius v wagon
    Does anyone know, first hand, if there is truly a difference in the method for replacing the water pump on these two generations? I've watched several videos and I'm seeing that some mechanics say you must drop the engine to get the pump off in the Gen 4 models yet in Gen 3, you can get it off under the hood without dropping the engine. I don't want to do more work than I need to by putting it on jacks if I can avoid it. I have a 2017 Prius V with 208k miles.
    Thanks in advance.
    Kathy
  2. rjparker
    8,100
    4,802
    There are two water pumps, one for the engine on the passengers side and the other for the inverter and transaxle on the drivers side.
    I will assume you are talking about the engine water pump. Your 2017 v wagon is gen3 and you can get it off pretty easily. Some do it from the top only although you have to feel for the bottom and back bolts to do it.
    Don’t use anything except oem Toyota water pumps, the aftermarket and counterfeit units fail quickly.
    Aftermarket (maybe Aisin)
    Online Toyota dealer
    #2 rjparker, Aug 21, 2024 at 6:55 PM
    Kpeeling likes this.
  3. Kpeeling
    28
    South Central PA
    2017 Prius v wagon
    Thanks. I was talking about the pump on the passenger side. I was thinking that the 2017 was Gen 4 since this chat site lists Gen 4 as starting in 2016. Maybe the next generation of changes aren't in the Prius V since it was being discontinued? I have bought an Aisin and can see where the Toyota name was ground off. Napa told me it was the same as OEM but cheaper. Should I replace the thermostat too while I'm in there?
    Thanks again
    K
    #3 Kpeeling, Aug 21, 2024 at 7:30 PM
  4. rjparker
    8,100
    4,802
    the v was gen3 through 2017 in the US and through 2021 elsewhere.
    I would change the thermostat or at least get the gasket.
    I would make sure Napa gave you a 2017 Prius v part and not a 2017 Prius hatchback part.
  5. Kpeeling
    28
    South Central PA
    2017 Prius v wagon
    Thanks. I'll double check in the am.
    K
  6. MAX2
    MAX2 Junior Member
    85
    Third Rock from the Sun
    What were the reasons for replacing the pump?
  7. Kpeeling
    28
    South Central PA
    2017 Prius v wagon
    The car was throwing the P261B code numerous times and then had an incident where the yellow warning triangle popped on and I lost power. It all reset and I was able to get home without overheating but through another thread on this forum and a conversation with my mechanic, I was convinced that the water pump was on the way out. It's original equipment so with 200K miles, it doesn't owe me anything. The plans are to tackle it today. We'll see if we can get it out without dropping the engine. Wish me luck.
    K
    V Sport Wagon likes this.
  8. ChapmanF
    15,855
    As other posters have mentioned, the v wagon remains a gen 3 Prius even in the years when the Prius liftback is gen 4. So you should not have a difficult replacement in your v wagon.
    For other readers, yes, the gen 4 liftback did make access harder for the pump. "Drop the engine" was indeed the original procedure suggested in the repair manual, but it turns out a little creativity with engine mounts and a jack is all that's really needed. PriusChat member 3prongpaul figured that out, and the Toyota repair manual was later updated. (Whether Toyota figured that out independently or 3prongpaul used their repair manual comment form, I don't know.) More at this post.
  9. V Sport Wagon
    V Sport Wagon Member
    266
    Southern California
    11 book hours at Toyota to replace a Gen 4 2ZR water pump. That's likely dropping the engine and whatnot..but mechanics know a few short cuts to work only about 4 hours or less and get the full 11 hrs. There's less than an inch between the fender well and the pump housing inside the Gen 4 engine bay, versus several inches in a Gen 3.
  10. ChapmanF
    15,855
    Interesting ... it was @Elektroingenieur who reported that the Repair Manual procedure had been changed from the earlier version with engine removal to a simpler procedure, and reported in the same post that:
    "11 book hours" sounds even worse than what the Flat Rate Manual said before the update. :confused:
  11. Mendel Leisk
    38,867
    Doesn’t Toyota also propose to remove engine/transaxle for Gen 3 timing chain cover reseal. Sometimes their mechanical engineers, technical writers and so on, seem to have a tenuous grasp at best, on practicality.
  12. rjparker
    8,100
    4,802
    Keep in mind most dealers pay their mechanics by book hours regardless of how fast they actually do the job. So an efficient mechanic can do several 8 hour jobs in one day.
    Toyota pays warranty labor based on book hours as well but at a reduced rate.
