Advice Needed! P0401, P0300, P0301, P0303 Head Gasket and/or EGR?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ALTEREG0, Aug 19, 2024 at 6:50 PM.
  1. Mendel Leisk
    38,868
    ^ worth noting.
    AFAIK NGK were never the stock-from-factory plug. Previous owner replaced, possibly counterfeits?
    I’d still be on alert regarding the head gasket.
    #21 Mendel Leisk, Aug 22, 2024 at 6:37 AM
  2. ALTEREG0
    ALTEREG0 New Member
    Monday
    Arizona
    Yes! Somehow I took the picture (or uploaded the picture) upside down
    “AFAIK NGK were never the stock-from-factory plug. Previous owner replaced, possibly counterfeits?”
    Actually, it was me. I just replaced the spark plugs around 3 weeks ago with a set I bought online. Now that I think about it I wonder if they were not gapped properly and also not torqued properly (cylinders 1 & 3 were very loose) Could also be a counterfeit issue for sure.
    "I’d still be on alert regarding the head gasket.”
    Absolutely. Cleaning the EGR asap, purchasing the oil catcher and procuring a borescope and gas test kit. Any other suggestions on how to proactively monitor the head gasket @Mendel Leisk?
    Thanks again for taking the time to help me, I sincerely appreciate it!
  3. Mendel Leisk
    38,868
    QUOTE="ALTEREG0, post: 3474569, member: 215215"]Actually, it was me. I just replaced the spark plugs around 3 weeks ago with a set I bought online.[/QUOTE]
    That's a revelation lol. Was that just before the symptoms/codes started? The plugs could well be the cause of the shake-on-startup. I would take it as wake-up call. Your EGR will be clogged, guaranteed with the miles, and head gaskets have blown well before those miles. Just keep an eye on the coolant level, get on that EGR cleaning as soon as you can manage.
    For sure get a set of Denso's, preferably from dealership; latest has the number 16 instead of 20.
  4. Mendel Leisk
    38,868
    Latest Denso part no is Denso SC16HR11 (used to be SC20HR11, per owner's manual, but revision is a slightly hotter plug)
    Toyota assigns it part no 90919-01275
  5. ALTEREG0
    ALTEREG0 New Member
    Monday
    Arizona
    Sorry about disclosing the new spark plugs so late/vaguely, I mentioned it on post #5 as an edit note.
    Yes, the spark plugs were replaced around 3 weeks ago (two weeks before the trip), no issues whatsoever before or right after installing the spark plugs 3 weeks ago. The car never shook or showed any other malfunction signs at all at start up or at any other point. Actually, no issues whatsoever until after the temperature warning light and CEL came on last week after going 75mph uphill during our camping trip. Definitely a wake up call.
    Do you think the subpar (to say the least) spark plugs were ok for a while (3 weeks before the trip) for city driving but failed when put under stress (high speed going uphill with ac on full blast)?
    Or do you think the clogged EGR caused the spark plugs to fail? (if that was the case, wouldn't the car have started shaking on start-up/idle before the trip (and even now with the new spark plugs)?
    I was just going to ask about the 16 and 20 you mentioned on your previous post, thank you for clarifying!
    Is there a particular oil catch can that you recommend?
    Thank you again for all your help!
    #25 ALTEREG0, Aug 22, 2024 at 3:22 PM
  6. Mendel Leisk
    38,868
    I wouldn't sweat oil catch can for now; it can be a bit of a rabbit hole. I've got a couple of Moroso 85474 air/oil separators (basically the same thing), in series, mounted on as bracket* atop the lower front beam, below the intake manifold. That location was a bear to deal with, and with two cans it JUST all fits, not touching the (sprung) engine or associated stuff.
    The Moroso 85474 have gotten crazy expensive, food for thought. They are a very solid product though, you'll need to put them in your will, lol.
    One gotcha with them: they have a large/thin o-ring at the seam around the midriff of the barrel. After opening/reassembling it a few times that o-ring stretched badly. I contacted Moroso for info, and these are the specs for the O-ring, plus they recommend to always lube it with anti-seize:
    O-ring info from Moroso:
    We do not list a replacement o-ring for that, but we do have them in our warehouse. You would need to call us direct if you wanted to get one ordered, or you can source an o-ring with the same specs; 2.614" I.D., .070" thick in Buna-N. What you saw on the threads of the catch can was anti-seize, we would recommend applying more to keep the top and bottom halves from seizing together over time. It is possible the o-ring was stretched or pinched upon reinstallation.
    Brett Corriveau
    Sales Support Technician
    Moroso Performance Products
    80 Carter Drive
    Guilford, CT 06437
    203-453-6571 x332
    [email protected]
    (66.40 mm I.D., 1.78 mm thick)
    The above spec is like O-Ring "dash" number: -038
    Search strings:
    O-ring -038 Buna-N
    Moroso 84574 Air-Oil Separator O-Ring:
    Oil-Resistant Buna-N
    Dash Number: 038
    (Relube with anti-seize periodically)
    Steel mesh biscuit part no: 85472059
    (only available by direct order from Moroso, $5 USD apiece)
    I was able to get those o-rings locally, had to buy maybe 10 of them for $20.
    * The OCC bracket atop the beam should be "loosely" mounted, says with a rubber gasket between it and the beam, with hold-down fasteners finger-tight-and-locked: the underside of that beam is the front jacking point, and it needs to flex.
    #26 Mendel Leisk, Aug 22, 2024 at 3:59 PM
  7. rjparker
    8,100
    4,803
    The fact that plug got that gummed up in three weeks is not great. But I would drive it frequently and watch for more shaking in the next three weeks. Which happens to be the interval new plugs clear the shaking on a hg leak. Realize the shaking does not occur if the plugs fire. Bad plug misfires and shakes are continuous while coolant fouling is short term as the engine starts or restarts with an advanced case while driving.
    In the past many people have temporarily cleared shaking with new or even cleaned plugs. Watch the coolant level as well but shaking is the first symptom.
  8. ALTEREG0
    ALTEREG0 New Member
    Monday
    Arizona
    Wow, $200+ dollars for that Moroso Oil separator, must be really good! Thank you for sharing all that information.
    What do you think about the damaged spark plugs?
    Do you think the clogged EGR caused the spark plugs to fail? (if that was the case, wouldn't the car have started shaking on start-up/idle before the trip (and even now with the new spark plugs)?
    Or is the culprit a bad head gasket that after a few weeks destroyed the spark plugs?
  9. ALTEREG0
    ALTEREG0 New Member
    Monday
    Arizona
    Oh I see, so you think that the spark plugs could have been ok but the head gasket leak eventually caused them to fail? Thanks for the help!
  10. Mendel Leisk
    38,868
    I’m not at all sure. Plugs could be counterfeit. Just the miles and lack of EGR cleaning has me thinking head gasket.
  11. ALTEREG0
    ALTEREG0 New Member
    Monday
    Arizona
    Fair enough, I will get the EGR cleaned as well as the combustion leak test and other head gasket tests asap. I will also monitor the coolant level closely. Thank you for all the help again, I appreciate it!
