AutelAP 200 fail!!
Discussion in 'Gen 2 Prius Technical Discussion' started by Tombukt2, Aug 22, 2024 at 8:01 AM.
  1. Tombukt2
    9,587
    1,680
    All tells Maxi app AP200 app apparently is not working across the boards and some kind of Android 11 update apparently this is affecting people across the spectrum of devices doesn't look like it's a device problem It's an Android problem so if you update or have updated your software and it's not working if you can revert to the old which can probably can't do you're screwed basically my white AP200 is a brick as of right now the AP 2500 works but it has no brake bleeding capability and other things so it's just a piece of well trash I guess anyway I do have Toyotas software so it's not a huge issue for me but just letting any of y'all know if you haven't seen it yet and maybe issues.
    49,689
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,528
    1,610
    NJ-USA
    Well, I get a "server communication failure" message when I try to login to my account. Since it's the same on two phones with different android versions, I'll assume there's a problem on Autel's end of things.
    update, tried logging in on my pc and it errored there as well, so autel has a problem
    #3 mr_guy_mann, Aug 22, 2024 at 8:58 PM
    Brian1954 likes this.
  4. mr_guy_mann
    3,528
    1,610
    NJ-USA
  5. Tombukt2
    9,587
    1,680
    Yeah I can't get the software to open on my Android 11 phone which is the phone I started with the AP200 with some update from Windows 11 is screwed that up apparently everybody on the site is noting that I don't have a windows option I don't think well I won't see my Bluetooth computer from the car I don't think I can get it close enough for the windows My phone yes I guess I need to try to put the autel on the tech stream computer
  6. mr_guy_mann
    3,528
    1,610
    NJ-USA
    Remove the Autel app then reinstall it on your phone - see what that does.
