Gen3 Intake Manifold Cleaning results in Check Engine and then Hybrid System Message
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Doug Pinkerton, Aug 24, 2024 at 10:34 PM.
  1. Doug Pinkerton
    Doug Pinkerton Junior Member
    Lehigh Valley, PA
    So, I've read numerous threads here about issues after cleaning the intake manifold. They all seem to mention engine that either won't run or runs very poorly and most posters then found a hose they forgot to connect.
    In my case, the engine started great and seemed to run fine but then the Check Engine Light came on and into a test ride I got the dreaded "Check Hybrid System Stop the Vehicle in a Safe place."
    Posting here on the off chance that someone sees this and has a thought. Tomorrow AM I plan to check my connections, but my hunch is that, if it were a hose, the engine wouldn't run and sound fine.
    Let me know if you have a thought.
    Thanks!
  2. Tombukt2
    9,597
    1,682
    Now ya read codes/s . How dirty was everything when you clean the intake did you bother cleaning the EGR cooler and it's piping? Sounds like you're doing this without a scan tool so maybe you did the cleaning and something else is wrong I don't know usually if you can read your code you'll get a pretty simplistic answer to deal with generally. Maybe a bad plug or a bad coil pretty simple and straightforward.
    Brian1954 likes this.
  3. ASRDogman
    ASRDogman Senior Member
    6,166
    3,309
    If you forget to attach the PCV hose, that is what you will get. Because too much air
    is being sucked into the cylinders and the engine won't start. What you are likely hearing
    is the engine turning over, but not starting.
    Remove engine air filter housing and check it. It's right behind the top smaller connecting is for
    the cooling lines. The pcv hose is about the size of a nickel.
    But you should check all the vacuum lines. It's easy to miss connecting them.
  4. Brian1954
    Brian1954 Active Member
    917
    348
    South Central PA, USA
    Like Tom mentioned, you need to read the trouble codes with an OBD2 scan tool. Once you have the trouble codes, then you can determine a plan to fix the problem.
