How to display speed limit?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Seymour1, Aug 25, 2024.
  1. Seymour1
    Seymour1 Member
    249
    29
    I have used a Garmin for years in my other car. Most driving is done on familiar streets. I mainly want to know the speed limit. I cannot figure out how to view the speed limit. How can I do this?
    Also, I can update my (low-cost) Garmin for free. Toyota should do the same. I will certainly get a Garmin for my 2010 Prius.
  2. Mendel Leisk
    41,012
    What's the Garmin model? Ours (a venerable Nuvi 2350) does show the speed limit (to the best of my recollection), and I've never changed any settings on it. Maybe just certain models show speed limits? Or yours used to? Also, ours doesn't always show the speed limit, especially on some short, secondary streets, guess it depends on the map data.
    Google Maps on our phones behaves similarly.
    (Thought I'd look up cost to update map on ours: it can't be updated; primarily because maps have gotten too large for it's capacity.)
    fuzzy1 likes this.
  3. fuzzy1
    10,337
    My Garmins have shown speed limits, but only when available in their database. Mostly on highways, rarely on city streets. Like Mendel's unit, the older one (used in my first Prius which lacked Nav) is now hobbled by too-small memory, so the database must be limited. The newer on, in the household Subaru, is better.
    Currently, most of my driving is in a RAV4 with RSA (Road Sign Assist) and HUD (Head Up Display). The car uses both the RSA to read speed limit signs, and a cloud-based database, to guess the current speed limit, and the HUD prominently displays it up where I notice far more than the Garmins were ever checked. It is convenient to "look back" at posted limits if I've forgotten or missed a sign.
    But it has plenty of anomalies. There are always some local speed limit changes somewhere around here, but the cloud-based database is never fully up to date, always lagging, there are disagreements between the database and current signage. On road segments with outdated info, the car shows the most recent RSA reading for a little while, then flips to the database number, then flips again at the next actual sign. Continual flip-flopping for extended periods. On one section of highway that had reduced speeds for construction for several years, the database still believes the reduced construction speeds are still in effect, despite the work having been suspended almost two years ago and PSL returned to full highway speed.
    The RSA has its own anomalies. Especially when looking into the sun, it has missed some signs that even my cataract-impaired eyes could read. It doesn't know the difference between passenger and Truck speed signs, so in the places where the car PSL is shown first, then the Truck PSL shown a couple seconds down the road, it latches on to the most recent and displays the Truck speed for a long time. Signs for Reduced Speed Ahead, cautionary speeds, and part-time school zones are mistaken for current PSL.
    So I can't help with any random Garmin, but do caution to be on guard for incomplete and outdated data.
  4. Tombukt2
    12,698
    2,269
    The speed limit is the speed I'm doing usually following one of your town's finest or something.
  5. BiomedO1
    3,175
    1,684
    SacTown, Ca
    On the older Garmins, there isn't speed limit posted on the display - Your travel speed color changes to red when you exceed the speed limit Garmin has on file in their database. That's if that option is available on your model.
    I travel in the mountains a lot and lose cell reception, so I rely on my Garmin when I'm out in the sticks in unfamiliar territory.
    @fuzzy1; most Garmins has a microsd card slot; just buy a good quality one gig card ,$5 on Amazon or Ebay.
    You can buy a top or the line used 4" Garmin w/traffic cable for $30 on Ebay - Still lifetime maps.... You may want to change the battery in it; if your taking it on a hike. Most of those batteries will only last for 5 minutes out of the car w/o power source.
    Hope this helps..
  6. fuzzy1
    10,337
    Already there. Failed, wouldn't split basemap between internal and SD, only other data.
    I know it is supposed to work on some, it seems mine isn't one of the capable units.
    And 1G isn't large enough anyway.
  7. Leadfoot J. McCoalroller
    8,017
    7,493
    Pennsylvania
    2018 Prius c
    I have some memory that the "Eastern USA" portion I kept in my TomTom was about 3GB, for the one file.
    It was a great machine; eventually I sent it to an upstate farm. I hear it likes to frolic and play with other portable road navigators in a big grassy field up there.
    I'm sure it knows where it is, even if I don't.
  8. Mendel Leisk
    41,012
    When I told Garmin what model I had it came back with “no update for you”. Not sure how you’d get past that, with extra memory card.
    truth be told I’m not that worked up about it.
