Serious questions about the solar option available in the Prime:
Discussion in 'Gen 5 Prius Main Forum' started by NonFormulaic, Aug 14, 2024.
  1. KMO
    KMO Senior Member
    1,564
    439
    Finland
    2023 Prius Prime
    Even down to the correct colour. ;)
    TGrracie likes this.
  2. Hammersmith
    Hammersmith Senior Member
    1,406
    1,443
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm still salty you guys got yellow and we didn't. lol
    (Though I've embraced the red since then, since I'm slowly switching my interior to the black/red combo.)
  3. hill
    8,253
    Alternatively - there's >90% UV/IR ppf that's typically used solely on glass auto roofs. Pricy - especially if applied to the entire car.
  4. AndersOne
    AndersOne Active Member
    299
    175
    Europe
    2023 Prius Prime
    Mine comes with solar panel and I see it as a playful gimick - similar to eg the seat ventilation theres not much point to calculate whether you get back the cost. Especially as youre forced to buy it anway for the higher trims in Europe.
    I doubt its too much different in the states - while you still have the theoretical option to configure solae yes/no it seems to come down in the end what cars are actually available and where.
    As for the solar panel itself, does anyone have clearer technical details regarding minimal energy that must be generated for the charger to actually charge the battery? Some kind of cutoff?
  5. EVPath
    EVPath Junior Member
    Deerfield Beach, Florida
    If you record the EV range, let’s say it’s at 20 miles or 32 km, then leave it in the sunlight for at least one full day (unplugged), do you see the range increase to 23 miles or more / 37 km? What about if you leave it for 15 days in direct sunlight, like at the airport…do you get a full charge?
  6. MAX2
    MAX2 Junior Member
    94
    24
    Third Rock from the Sun
    This is fantastic!
    The area of solar panels on the roof of a car does not provide much energy. Most of the light is reflected or heats the panel body. For home use and charging backup batteries, a large panel area of several tens or hundreds of square meters is needed.
    And not all airports are flooded with sunlight for 15 days))
  7. Trollbait
    11,632
    Toyota was saying something like 4 miles a day.
    @fuzzy1 worked out some annual miles from the solar in another thread. In L.A., it was 1100 to 50 miles a year depending on the season.
  8. NonFormulaic
    NonFormulaic Member
    60
    45
    San Diego
    What are the chances of info being spread (erroneous or not) on Google which questions the true safety of long term exposure to whatever due to sitting 5” directly under solar panels? Not worth opting in, even if there’s a 2% chance of this. How might this affect resale….not to mention your previously high functioning brain?
  9. Hotdog453
    Hotdog453 Junior Member
    44
    Ohio
    2024 Prius Prime
    XSE Premium
    My wife just got hers on Friday, and will be a prime (heh pun) candidate for it: drives approximately 35 miles a day round trip, and car sits outside at the office. Very curious to see how it works for her.
    if nothing else it does give a smidgen more headroom inside, compared to the glass roof I think. She had zero interest in the glass roof aspect, and the nerd in me enjoys the idea of the solar roof.
  10. MAX2
    MAX2 Junior Member
    94
    24
    A tinfoil hat will help you save your brain, survive all hybrid disasters, and even evil aliens.))
