Auto Power OFF
Discussion in 'Gen 4 Prius Technical Discussion' started by vertex, Aug 17, 2024.
  1. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    On my 2006 Prius, I used it as a power source for my house with an inverter. I could leave the car on, and it would run for days. On my 2021 (also my previous 2017) it turns off after about an hour. This is not convenient if I need to use the car for the power source again. I have only needed to do this once, but it only lasted for a few hours. The power outage at Super storm Sandy lasted for days. It would be really nice to be able to disable this feature. Anyone familiar with it?
    Thanks,
    Howard
    (If this is an old topic, I tried to find it, but couldn't, so sorry.)
  2. ChapmanF
    18,569
    There have been threads about it before, some of which include the dance that can be used to disable the auto off. (If I remember right, it doesn't stay disabled; the dance is needed whenever you have the car on and don't want it to turn off.)
  3. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    Closing the door with a mechanical key allows the machine to operate without turning off after an hour.
  4. vertex
    672
    144
    new york
    2018 Prius Prime
    Ok, Max2 i'll try that next time I need to run my inverters, thanks.
  5. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    It's too bad there isn't a car camping section for the Gen 4 and 5 Prius and Prius Prime. The Gen 4 and 5 Prius are complicated to keep in camper mode and the Primes are ever harder, under all conditions and variations of equipment added for camping and backup power.
