Dome light, key fob, clock, no radio, VSC
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by paul2102, Nov 4, 2018.
  1. Rick0757
    Rick0757 New Member
    Cleveland
    man I wish you could make a video and send it to me cause I have an 08 Prius doing the same thing. I’m trying to follow your directions but I’m more visual.
    #101 Rick0757, Oct 9, 2019
  2. Pietro_S
    Pietro_S Junior Member
    Sweden
    Active
    Have you taken apart your plastic part in front of the fuse box inside car on driver's side?
  3. Ross Rabelow
    Ross Rabelow Junior Member
    Great chat everyone. I just followed your instructions on my 2005, that I recently purchased, and all of the functions you mentioned came back to life (radio, dome lights, fob, etc.). Thank you!
    I have worked on over 100 Prius' installing reconditioned hybrid batteries, and now remember that many have had this issue, especially 2004s and 2005s. I actually thought that the fob had limited functionality in some models. This is a very common problem.
  4. Knightrider
    Knightrider Member
    146
    34
    Kansas City
    Glad to see this is helping people.
    I had almost given up - but was very happy to see its helped 04/05!
  5. PNWbluegen2
    PNWbluegen2 New Member
    Seattle
    I'm actually having a bit of trouble following these instructions to get dome light, radio, SKS fob back. Any chance you could give me a summary of what steps i should take?
    So far - I have checked dome fuse, it is good, but I get no voltage in the fuse's socket ( to ground).
  6. LegoManiac
    LegoManiac New Member
    Brooklyn
    This happened to me when I was trying to change the Dome light from the original halogen bulb to an LED.
    I swapped out the 15 AMP "Dome" fuse with the spare and the problem was solved.
  7. Blue Line Guy
    Blue Line Guy New Member
    Long Island
    A BIG Thank You to Knightrider!!! Our Daughter's 2008 Prius suddenly had the same issue of Key Fob, Radio, Nav, Clock and VSC light steady on. I finally ordered inline fuse from Amazon and installed the other day to see if it would work on our daughters Prius before she returned from college. It did!!!! Our daughter was sooooo happy!!! Just wanted to let you know all YOUR hard work has made an 18 year old girl happy!! (and her parents) Thank you again!!
  8. racrx87
    racrx87 New Member
    Today
    Tucson AZ
    A quick warning that this issue may be water related, as others have noted. 196k ‘05 Prius here with no other electrical issues other than the combination meter I replaced about a year ago.
    Went through an automatic car wash with rinse and blow dry and then immediately got gas afterwards. Upon restart after fueling this issue of all the names systems not working occurred. Luckily I went straight to PriusChat to find the answer, and even more luckily (so far) it was just a blown dome light fuse.
    My guess is water dripped somewhere into the left footwell area during the car wash and shorted out this circuit. Hoping there was no wire damage and that the fuse did its job. Just a warning to be wary of automatic car washes and the damage water in the wrong places can do.
