2010 prius won't start after running out of gas
Discussion in 'Gen 3 Prius Main Forum' started by David Lang, Aug 26, 2024 at 10:35 PM.
  1. David Lang
    David Lang New Member
    Monday
    simi valley, ca
    I've been doing a bunch of digging over the last day but am stuck. My dad run his 2010 prius out of gas last night.
    It is reporting a hybrid system problem.(the battery pack was replaced a few years ago and shows 2 bars remaining)
    It also has all warning lights lit up
    I added 7 gal of gas.
    I've checked for codes using torque, none reported (I tried clearing codes anyway)
    I made sure the 12v battery is fully charged
    I've disconnected the 12v battery for a while and tried
    I've put the vehicle into maintenance mode
    but I don't hear it even try to crank the ICE motor
    I don't know how many times my Dad and AAA attempted to start the car before I got there and they decided we needed to tow it home.
    (and just to complicate things, the hood latch is damaged in a separate incident, so I will have to cut metal to get the hood open)
    Any suggestions on the next thing to try? (apologies if I've missed something obvious, but from the list above, I have done a fair bit of digging)
  2. Tombukt2
    9,635
    1,686
    I mean having two bars left in the hybrid battery after running out of gas I guess it took a while for somebody to register they were out of gas and they were trying to restart the car restart the car restart the car because well whatever reason old and hard-headed whatever it is so that may be an issue now after it sits about 11:00 or 12 hours it'll surface charge again a little bit so I wouldn't think that's your problem the 12 volt is fully charged and showing 12 volts if you short the 12 volt with a coat hanger wire and a pair of gloves it gets real hot the coat hanger wire and then when you measure the 12 volt with your flukey your back up to 12 volts directly not in an hour? Then you should be good when you put your car on and all that do you hear the fuel pump running If you get near the back seat you can If you have codes lit up the lights like you say you need to really read the codes and see what you got obviously 3190 or what have you for the car not the ice not starting but there's other things possibly You need all those codes without the codes you're just pissing in the dark
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    728
    286
    Maine
    I have heard stories of fuel pump losing prime when the tank goes empty, and having great difficulty in re-establishing prime. You need to reprime the pump.
  4. ASRDogman
    ASRDogman Senior Member
    6,183
    3,314
    The hybrid battery may be too low to turn the engine over. If so, you'll need to
    charge it up enough to be able to turn the engine over so it can start.
    You could try running the fuel pump with a jumper for maybe 15-30 seconds to make
    sure you have fuel in the lines and pressurised.
    What codes did you get for the hybrid battery?
  5. David Lang
    Monday
    simi valley, ca
    There are no codes read via the ODB2 interface, the dash shows the hybrid problem banner.
    The car did sit for 12+ hours after it was towed home before I started looking at it. And the battery did get disconnected before I tried to read any codes.
    what do I need to do to get the fuel pump to prime? or to manually run it?
    there is a little bit of a wirring sound from the car at some points, but it's not clear where it's from.
    I thought the starter was powered by the 12v battery? (after all, you can jump start it via 12v)
  6. ChapmanF
    15,877
    if it doesn't even try to crank the engine, battery state of charge would be my guess.
  7. David Lang
    Monday
    simi valley, ca
    I fully charged the 12v battery
  8. MAX2
    MAX2 Member
    118
    28
    Third Rock from the Sun
    The starter here is a motor generator, which is powered by a high-voltage battery and an inverter converter. Hundreds of volts.
    A 12V battery is needed to start and check all systems, turn on the high-voltage battery relay contactors. If the high-voltage battery has problems during testing, the contactor will not turn it on and will not supply power to the inverter. Therefore, you will not hear the sound of the motor spinning up.
    If you have an OBDII scanning device?
    Then you can connect Android programm Dr.Prius.
  9. ASRDogman
    6,183
    3,314
    Okay? Then what? 30 minutes after taking the charger off, what was the voltage?
    What else have you done? Are you going to be getting a code reader that will
    work with the Prius so you can read the codes for the hybrid systems?
  10. Mendel Leisk
    38,883
    Will 2 pushes of start button without foot on brake (aka “on”, car fully awake but engine not started) light the display that shows hybrid battery state of charge? I think so.
  11. David Lang
    Monday
    simi valley, ca
    re: starting, interesting. I have run the 12v battery down before and needed to jump start the car, I didn't realize that was only for the electronics (and we replaced the HV pack a few years ago, it was pretty dead, but never had a problem starting.
    When I turn on the car (two presses of start) it shows 2 bars for the HV pack
    trying to cover what was done in order
    initially they added 1-2 gal of fuel and tried to start it, AAA attempted to jump start it (why, I don't know, the 12v battery wasn't dead)
    we towed it home
    after doing some quick google searches, I disconnected the 12v battery for 10m or so and then reconnected it and tried again. After trying this a while (while doing more searches on my phone) the 12v battery was getting low, so I put it on a charger overnight.
    again disconnected the 12v battery for several min
    added 5 more gal
    again disconnected the 12v for several min
    hooked up an ODB2 reader with torque (I just downloaded dr prius), no codes reported, reset codes anyway
    tried putting it in maintenance mode (a few times as I wasn't sure it really worked, I got the maintenance mode message on the display, but nothing else, I finally watched a video and saw that the ICE was expected to turn on after a few seconds)
    it appears that dr prius isn't happy with the odb2 readers I have :-( I'll have to order another one. Torque connects to them, but dr prius doesn't, and when I load the prius pid pack into torque, it doesn't show any data for the prius specific things
    It's now only showing one bar on the HV pack
    here are pics of the two odb2 readers I have and the dash showing everything lit up
  12. David Lang
    Monday
    simi valley, ca
    here are the insides. I've ordered a couple more odb2 readers from the recommended list (panlong and veepeak ble+) and will try dr prius with those once they arrive
  13. ChapmanF
    15,877
    Yes.
    The state of charge of the (high voltage) traction battery was what I had in mind, as that's the battery used to crank the engine.
  14. Mendel Leisk
    38,883
