just got a 2010 Prius - need advice
Discussion in 'Gen 3 Prius Main Forum' started by Ed Geis, Aug 22, 2024 at 9:15 AM.
Tags:
  1. douglasjre
    douglasjre Senior Member
    1,904
    662
    Orlando, FL
    If you're not am ASE Certified mechanic willing to replace the engine and hy rid battery, sell it now while it still works(y)
    Grit likes this.
  2. Grit
    Grit Senior Member
    6,154
    4,063
    Wilkes Land
    The days of this car being bullet proof are soo long gone.
  3. MAX2
    MAX2 Member
    118
    28
    Third Rock from the Sun
    Bulletproof.
    Brought back memories.))
  4. Ed Geis
    Ed Geis New Member
    Thursday
    Maine
    I
    Thanks--I checked the washer fluid level, it's fine. And the rear washer works so I figured the fuse is OK. Can't image Toyota fuses each washer pump separately...or do they?
    Taking it into a local independent shop this afternoon for a closer look. Son is taking it to school Friday morning. Will check/clean the battery fan but may not get to the EGR pipe before he leaves. Maybe on a weekend when he's back home.
    I looked for a transmission fluid dipstick but didn't see one. How do you check the fluid level on these babies?
  5. ASRDogman
    ASRDogman Senior Member
    6,183
    3,314
    I don't know how close the motors are, but you could switch the electrical connections
    and then try the washer again, it if sprays out the back, you know it's the pump.
    You can also put a meter on the connector, have your son try the washer, with the car in
    ready mode. If you get 12 volts, you know it's the motor...
    Cleaning the egr pipe is a waste of time if you are not going to clean the cooler, and the
    3 holes for the egr gases on the intake manifold...
  6. bettergolf
    bettergolf Active Member
    436
    340
    Sanford NC
    There is no dip stick for the transmission, only a drain plug and a refill plug underneath.
  7. Mendel Leisk
    38,883
    not completely: it gives you some idea, and might get you motivated, to “push on”.
  8. Ed Geis
    Ed Geis New Member
    Thursday
    Maine
    I
    So does the blown head gasket issue frequency correspond at all to oil change intervals? That is, if the oil and filter are changed at recommended intervals does that vastly reduce the risk? Or is this happening regardless?
  9. Mendel Leisk
    38,883
    The EGR will still get carbon-clogged, and in my opinion, that is what is causing head gaskets to blow.
    More frequent oil changes "may" help mitigate the piston ring clogging and ensuing runaway oil consumption. The ultimate cure for that is to replace either the piston/rings, or the complete short block.
    FWIW, for one reason or another I've done very frequent oil changes on our '10 (has the "low-tension" piston rings), since new purchase in November 2010. Odometer's currently at a mere 101K kms, and so far no discernable oil consumption, at least going the by the dipstick.
    I've also done two EGR cleanings. The first was at 71K kms, and there was significant carbon build-up. No where near the conditions people are reporting, say when cleaning at 100~150K miles, but that's fine by me.
    #29 Mendel Leisk, Aug 28, 2024 at 11:40 AM
  10. rjparker
    8,112
    4,808
    It does happen regardless of egr cleanings and oil changes on 10k intervals. They may delay the problem if no oil burning exists and frequent engine coolant changes occur.
    Recommended oil change intervals was part of the problem. Toyota went from 5k intervals on gen2 to 10k miles on gen3 and then changed people’s habits by doing the first two free.
    The engines burn no noticeable oil when the rings are good; my egr flowed freely for over 100k miles with no oil burning. By 150k miles it was burning oil and the egr cooler, valve and intake was getting gummed up. After oil burning starts there is no turning back without a rebuild with revised rings and pistons. Toyota had a TSB and provided free rings and pistons if you burned more than a quart in ~1200 miles.
    There are also revised intakes, egr valves and ecu software for gen3. With all of that proactive recommendations from Toyota, they still do not recommend egr system cleaning or replacement before it codes.
  11. bbrages
    bbrages Member
    104
    24
    St. Louis
    Keeping the oil changed regularly should help avoid the high oil consumption that occurs with coked-up rings. On my 2010, the maintenance reminder comes on every 5000 miles. I think it was originally 10,000 miles but there might have been an update to reprogram it at some point. ??
    It's not proven what causes the HG to blow in these cars. My guess is it is related to the electric water pump, either poor programming or reduced performance as the pump ages. The EGR theory doesn't make sense to me because I don't know of any other model of car where EGR clogging leads to blown head gaskets. But it's a good idea IMO to keep the EGR passages clean anyway.
  12. Mendel Leisk
    38,883
    Yeah, I think both people and corporations do things for reasons. Toyota's motivation in this matter seems a marriage of dodging responsibility and spending as little as possible. I do think the highlighted statement could be easily and successfully challenged in a court of law:
    The 240,000 km limit mentioned in the above converts to 150,000 miles.
    Somewhat similar to how they "stand behind" the 3rd gen's low-tension piston rings, for 60K miles...
    #32 Mendel Leisk, Aug 28, 2024 at 12:43 PM
  13. Ed Geis
    Ed Geis New Member
    Thursday
    Maine
    I
    Can I access it just by removing the passenger side inner front fender?
  14. Ed Geis
    Ed Geis New Member
    Thursday
    Maine
    I
    Hmmm...so the pump flow rate declines, leading to elevated motor temp.? I suppose I should add a cooling system flush and pump changeout to my punch list. Guessing that access to the waterpump is a nightmare.
    Guessing that vehicle has to be under warranty for them to honor that? Or not? Will try and keep close tabs on the oil level. I checked the dipstick before purchase and the oil was full and very clean.
    Why frequent coolant changes? Does the coolant go bad that quickly? I know back in the day I used to change mine every 2 years but that seems excessive now from what I read about modern coolants.
  15. Mendel Leisk
    38,883
    Looks like. Attached is all the windshield washer section from Repair Manual. Mercifully, the motor access is near the front. Looks like two motors, one for front, one for rear, can both be accessed through passenger side front wheel well. You do need to at least partially open up the wheel well liner.
    While doing that, I would check for timing chain cover oil leaks; it's right there.
