Prius went from 45 mpg to 22-30 mpg after sitting for three weeks?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Falcon143, Aug 28, 2024 at 11:49 AM.
  1. Falcon143
    Falcon143 New Member
    Austin
    Hi hybrid battery is refurbished but on the newer side. Gas mileage was great at 45 mpg, I left town for three weeks and now it’s getting 22-32 mpg. Tires are good, brand new 12 volt battery. I’ve never had a hybrid battery go out so drastically. Any other causes? Spark plugs were replaced a few years ago and I only drive it locally and not often since then. I’m hoping it is not the hybrid. Odd that after sitting it shifted so quickly. Brakes got changed during this time, there’s still some squeaky noise when not breaking sometimes.
  2. Tombukt2
    9,640
    1,687
    Maybe the brakes are dragging or something the rears are drums some people don't work on those so well I don't know but yeah that's a you know half of your mileage drop I mean generally this happens if I pull the trailer yeah even just locally things like that but I mean a couple year old spark plugs really shouldn't make a lot of difference unless they are at the end of their lives regardless generally what goes in these are 100,000 mile SK16s
  3. JC91006
    JC91006 Senior Member
    16,494
    8,404
    The problem is 99% the rebuilt battery that sat for 3 weeks.
  4. PriusCamper
    PriusCamper Senior Member
    11,198
    4,560
    Pacific Northwest, USA
    Low tire pressure can cause this. Boost your tire pressure up near 40psi... Also fully charge up your new 12volt with a legitimate charger in the 10amp range because Prius are lousy at quickly recharging 12volt if its been sitting and draining for a while... Also maybe you bought some bad gas, so drive it more often to get a fresh tank of gas in there asap.
    How stable is the charge on HV battery? Does charge level move often? Do they stay stable / just under green bars most of the time?
    Lastly, how many miles on it? Have you had regular maintenance?
  5. MAX2
    MAX2 Member
    132
    29
    Third Rock from the Sun
    Need to figure it out.
    Is your high-voltage battery dead?
    Or is your mileage reduced after replacing the high-voltage battery?
