2010 prius won't start after running out of gas
Discussion in 'Gen 3 Prius Main Forum' started by David Lang, Aug 26, 2024 at 10:35 PM.
  1. David Lang
    David Lang New Member
    Monday
    simi valley, ca
    The orange connector hasn't been touched, so it should be (doesn't look like there is anything wrong)
    So my options seem to be, spend $300-500 for a special charger, disassemble the pack to charge each cell individually, build my own charger, or take it to a shop?
    the vehicle doesn't have any way to provide power to the HV pack itself without the engine running?
  2. MAX2
    MAX2 Member
    138
    34
    Third Rock from the Sun
    The problem code P0A0D for blocking has subcodes.
    The high-voltage system includes a high-voltage battery, high-voltage wiring, inverter, compressor for the air conditioner. Therefore, the subcode for the error will tell you the location of the problem more accurately.
    What high voltage skills do you have? Auto electrician skills?
    A lot depends on this.
    Until you find the location and point where the lock is broken, even with a charged battery, the hybrid system will not turn on. The Prius is designed to prevent accidental high voltage shock.
  3. David Lang
    Monday
    simi valley, ca
    no particular HV skills, I've done a lot of automotive and ham radio electrical, home outlet replacement, etc
    since the car was working before it ran out of gas and was driven until it stopped, there's a pretty good chance that it's only a low charge problem (there would have to be multiple failures in a very short time for anything else to go wrong)
  4. MAX2
    MAX2 Member
    138
    34
    The fastest way is with the Prolong device or its homemade analogue.
    A high constant voltage of 240 volts and higher is supplied to the high-voltage battery.
    The charging current is 0.2-0.3 A. All modules are charged at once.
  5. ASRDogman
    ASRDogman Senior Member
    6,189
    3,314
    Are you going to check the fuel pump????
    Running out of fuel for any electric fuel pump is bad because the fuel
    cols the pump, no fuel, no cooling, pump can burn up quickly.
    Since enough fuel was not installed, and you kept trying to start the car, it's likely
    the fuel pump is burned out.
    Manual applying voltage to the pump could tell you if the pump is at least running.
    You can "rig" different chargers to the hybrid batter to charge it, but it is highly risky.
    It's a DV battery, so if you have any experience with electricily, it's the same.
    You could do a search in your area for a hybrid shop that could possibly charge it
    for you, and test the fuel pump.
    Plus, with the Prolong charging/discharching system, you can run through the charge/discharge
    cycles and possibly bring new life to the hybrid battery which can help it last longer.
  6. David Lang
    Monday
    simi valley, ca
    I think I heard the fuel pump whir when I worked on it today. short of pulling out the back seat, is there a way to test the fuel pump?
    The hybrid battery was replaced in 2021, and the car isn't driven much (probably somewhere around 30 miles a week)
  7. sylvaing
    sylvaing Senior Member
    1,144
    478
    Don't the dealerships have a special charger to charge a depleted HV battery? Why not bring the car to your dealership?
  8. MAX2
    MAX2 Member
    138
    34
    Moving a car that won't start requires at least one horsepower))
  9. Mendel Leisk
    38,889
  10. ChapmanF
    15,885
    I'm not sure every dealership has one. Maybe by now they do. At one point, it was definitely equipment provided by Toyota per sales region, and if your dealership needed it, they'd go on the list for one from regional to be brought to them, along with the specially-trained technician to run it.
  11. sylvaing
    1,144
    478
    Hmm, if they sell it, they should have the means to service it.
  12. ChapmanF
    15,885
    They do. They just keep some of those means at the region HQ.
  13. David Lang
    Monday
    simi valley, ca
    a local hybrid repair shop said "yep, we see that a lot with those prius, we'll be happy to sell you a new HV battery pack"
    I'm waiting for a call back from the local toyota dealer. the person I spoke to said they do have a charging station, but I don't know if that's something that can charge this pack, or if they are talking about a CSS charging station that can charge a plugin hybrid/ev.
  14. ChapmanF
    15,885
    Just noticed this post. The P0A0D code pertains to the safety interlock circuit that makes sure you have the right connections made and covers in place at the inverter and the battery service plug fully installed. It does have a couple of subcodes, but those only tell you when the condition was detected. Subcode 350 means it was detected while the car wasn't being driven, and locks out the hybrid system. Subcode 351 means it was detected while the car was being driven, and displays the warning without immediately shutting the car down, so you can get to a safe place.
    Because all the safety interlocks are on a simple series circuit, there isn't any way the code could pin down the location for you; if any one of the interlocks isn't made, all the ECU can see is that the circuit is open, not where the open happens to be. Helpfully, there are only a few places to look.
    The different code P0AA6 (the one about high-voltage isolation being compromised) does have subcodes that narrow down which portion of the high-voltage system is suspect.
