Can a new 12V reading high, cause Ignition Coil to misfire?
Discussion in 'Gen 3 Prius Main Forum' started by analoggirl, Aug 29, 2024.
  1. analoggirl
    analoggirl Member
    155
    28
    Asheville, NC
    IMG_9971.jpeg IMG_9970.jpeg IMG_9969.jpeg I replaced a 12 V with a Toyota battery last week. The car was shaking like crazy on start up this morning, check engine light is now on. I stopped at AutoZone to run codes. See the pictures for results. I'm wondering if the fact that my 12 V is reading at 14.17 V Caused any issues?
    2011 Gen3, 206,000 I replaced the main hybrid with Toyota battery last year, water pumps and brake pump also replaced in last year with Toyota parts.
  2. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Most likely you have a head gasket needing repair/replacement. Major work...sorry. Battery reading 14.7 is normal and would not cause a problem.
    Brian1954 likes this.
  3. Tombukt2
    13,859
    2,519
    You didn't read up on these beforehand yeah you're heading for all kinds of fun I envy you not
  4. bisco
    52,854
    That reading is the inverter charging the battery
  5. analoggirl
    analoggirl Member
    155
    28
    Asheville, NC
    So I'm befuddled, how is a 12 V battery reading 14.x
  6. analoggirl
    analoggirl Member
    155
    28
    Asheville, NC
    but it's 14+ whether it's been sitting off, or after I turn it on for 30 minutes. Never below 14. And why would a 12 V battery stay at 14+
  7. bisco
    52,854
    If the car is off, a new agm battery should measure close to 13v
    I’m wondering about your meter
  8. Tombukt2
    13,859
    2,519
    If you're checking the car's battery while in ready mode you will see about 14.5 volts now turn the car off Wait 20 minutes take another measurement it'll be around 12:00 If it's under 12 that's problematic You need 12 volts in the 12 volt system not 11.9 or any of that
  9. analoggirl
    analoggirl Member
    155
    28
    Asheville, NC
    Thanks
  10. ChapmanF
    19,020
    A reading like 14.2 when the car isn't READY is kind of a mystery. Like bisco, I'm wondering about your meter.
    But anyway, I doubt that mystery is behind the misfiring—after all, the system voltage is around 14.7 a lot of the time when the car is READY, and the ignition coils work fine then.
    Inconveniently, misfiring can have a lot of causes and checking them all can be hard. The P030x codes you have are not specific to the ignition coils; those codes only tell you misfiring is happening, nothing about why it is happening. (If you had P035x codes, which are specific to ignition coils, that would be a different story.)
    There's kind of a helpful article on misfire diagnosis in the Second Quarter 2009 issue of Toyota Tech (starting on page 15).
    There will be a chorus wanting to jump right to "blown head gasket" as if nothing else ever causes misfiring, but lots of things cause misfiring. So at your mileage, you might want to do some of the tests earlier rather than later that can rule a head gasket leak in or out, but still not assume the worst until a test shows it.
    Mr. F likes this.
  11. analoggirl
    analoggirl Member
    155
    28
    Asheville, NC
    when you say tests, I'm assuming you mean taking a look at the article you referenced? My question on that is that the article is from 2009, and my Prius is 2011. Do you have a read on a rundown of things I might want to consider?
  12. ChapmanF
    19,020
    The article is from a 2009 issue of Toyota Tech, which is from when the gen 3 (model year 2010) came out.
    That article tells you about some of the gen 3 ECM features that can help you diagnose a misfire. It kind of assumes you picked up gasoline-engine basics somewhere and know the basic things (fuel, compression, spark) that need to be checked and how.
    The head-gasket chorus would want you not to spend too much time looking for other causes, in case it is the gasket and there could be risk of further damage. So where you might, with a younger engine, start with the easier tests like fuel and spark and leave compression testing for later if you don't find an easier problem, at your current mileage you might move compression testing toward the front, as that's one of the ways to detect a gasket leak.
    Many here have suggested the best test for the gasket leak is to pressurize the cooling system and use a side-camera borescope through the spark-plug holes to see if any drips of coolant form in the cylinders at the junction with the head.
  13. analoggirl
    analoggirl Member
    155
    28
    Asheville, NC
    Thank you. You are always generous with your knowledge, and it's greatly appreciated!
    Mr. F and bisco like this.
  14. Tombukt2
    13,859
    2,519
    Pull the spark plugs out Make note of which cylinder they go in and as you pull one out look at it with a small magnifying glass You're looking for micro water droplets and you probably will see some Note the cylinders that they are in Note the other ones are dry probably where your misfire is beginning or such.
