Red triangle but good mpg
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dahvid, Aug 30, 2024 at 3:49 PM.
  1. Dahvid
    Dahvid New Member
    Today
    Usa
    Looking at buying a prius. Owner says mobile mechanic said cell 10 was low but still in range. They just took a roadtrip and still got over 40 mpg. It also won't start until codes are cleared; has red triangle
    I guess my questions are:
    Can you still get mpg like this with a bad cell?
    Could it be the 12v starter battery that's causing this?
    I'm more concerned it could be something else. Any thoughts?
    I hope that's enough information.
    Thanks for any and all input.
  2. Tombukt2
    9,661
    1,688
    More than likely you have the hybrid isolation fault this requires you to clear the code to generally drive the car starts and drives normally charges relatively normally gets pretty normal gas mileage and so on
