How to refill refrigerant.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vallesj, Aug 22, 2024.
  1. vallesj
    vallesj Junior Member
    91
    When we replaced an exploded engine on my kids 2011 prius, i asked my son to disconnect the ac compressor from the engine while I worked on engine bottom bolts. Suddenly I hear a shhh sounds, which I immediately understood he was disconnecting one of the hoses from the compressor so I told him to tight it back quickly. It was like 3 to 5 seconds so not so much refrigerant escaped. Now that everything else is working fine, I decided to check what to do about the ac. It is still cooling the cabin, but the air is not as cold as before and it takes much longer. I Checked the manual posted here to troubleshoot it, and there is bubbles when running as indication of low level of refrigerant. Too much money expended already on the car, even we just spent on spare parts, so trying to figure out if there is a cheap way to refill the amount of refrigerant escaped without the need of vacuum. By the way, I noticed the ports high and low are females, so normal recharge cans with a hose uses female connectors. And I haven't found a male adapter to buy. If there is not an economical way to fix this, they will have to drive it is under current hot Texas summer. So any good intended orientation will be appreciated.
  2. Tombukt2
    9,667
    1,688
    In the case of the Prius with the electric compressor you just get you some virgin generic 134a and you're not even going to use a half a can so I don't know what you're going to do with the rest that should clear up your bubbles put you back to where you were without having to discharge reweigh redo anything. That's how I do all the mine and they're all still working heading to various mileages over 300 so oh well
  3. PriusCamper
    PriusCamper Senior Member
    11,200
    4,561
    Pacific Northwest, USA
    The required refrigerant and lubricant is measured by weight inside a machine after its evacuated from the system. Because it is a variable pressure system, that is the only way you can get the right amount in the system. People who make the mistake of doing it by pressure from a refill can from the store often end up with a failed compressor in a year. Your best bet is to take it to an auto AC specialist and have them ensure you have the right amount in the system.
    Mr. F likes this.
  4. rjparker
    8,123
    4,812
    Really old r12 vehicles or residential systems use 1/4” screw on connections with core depressors. If you have a 1/4” gauge set you can buy r134 quick connect adapters almost anywhere.
    The biggest problem with diy on these full electric compressors is using R134 that has standard oil, dyes or sealers. Those extra chemicals can ruin the compressor windings.
    The right way to do this is recover, vacuum and weigh in new refrigerant and a small amount of hybrid specific oil.
    But I and others have added small amounts of pure r134 using the sight glass. Only a small amount at a time allowing a few minutes for the system to stabilize each time. And then stopping when the glass just starts to clear to avoid overcharging. You want to have the windows open, turn off recirc and have the fan speed to high to maximize the load.
    I would think you could find a shop that has hybrid experience to do it right for $200. The refrigerant is cheap.
    #4 rjparker, Aug 22, 2024
    Mr. F and MAX2 like this.
  5. Mendel Leisk
    38,892
    I had a dealership evacuate and recharge done, around 2016 IIRC, was $168 CDN out-the-door. With elapsed time and inflation, $200 USD sounds about right.
    PriusCamper likes this.
  6. Tombukt2
    9,667
    1,688
    You remember the old r22 days with the fittings described above you just screw them on gassed up the mess and did whatever used to sight glass. Have you ever overcharged an old r12 system probably a mistake but anyway if you've done that before you see when you get a good bit overcharge the compressor will start to lock up the clutch will start to slip It can't pump the fluid.? You back off the gas back in those days you just cracked your service valve on your gauges and let some out squirt squirt squirt turn the car back on now the air conditioner runs perfectly that sort of thing.? In the electric compressor genre If you overshoot the minutest amount of gas into the system you will hear the electric compressor start to stumble almost immediately I mean this is like barely over I did this once in a Prius the first time I had one and before the compressor could go stupid and lock up permanently damaging it I let some out watch the sight glass got it where I know I like to have it with r12 and all the years of doing that. And that was that that car today is still running and ice cold it will run you out of the car on a 97° day or when you get out of the car you'll pass out because you're so cold and it's so hot outside. So you can measure and do all that stuff you want and follow the EPA guidelines because you need to do that or what have you I usually just top mine off when I get them it's one of the first things I check when I get the whole car most of these cars I pull out a towing lots are still gassed up everything plugged up ready to go these cars it's a last-minute thing to get to the towing lot The mind said is I just replaced this this old car I'm not doing that and then that happens and the next day is at the towing lot that's how fast this goes on and the next couple hours I go by the towing lot see the back end of the car and well that's that. So if you're Johnny on the spot with these things you're getting the car that just came off the road probably for some nonsense or for somebody's personal internal trauma whatever.
  7. vallesj
    91
    Yes, the old can and hose set I have was different, it had threads.. so I bought one hose from Walmart for $19, and a can of R134 for $9.99... injected just few pushes, like 15 momentarily. Observed the pressure gauge, which was on the low green area, moved a little bit up more to the center of the green area. That day I could not feel so much improve, and was thinking to go to an AC shop the next day, but the next day, before going to the shop, it was cooling better... like if the gas takes time to settle inside... The window indicator still is murky when ON, but I don't want to overcharge it and be damaged later. So I decided it could be fine like that. If my kid wants to invest on having it refill properly it will be his decision. But now that car is working really good after changing the engine, replaced 11 modules I got from ebay for $22 each, no more "check hybrid system" error, replaced intake valve and replaced oxygen sensor on the new engine with the one from the broken one. So far so good with no more DTCs... Time will tell how much more will last.
  8. Tombukt2
    9,667
    1,688
    Yes Time will tell that is the prolific statement in these paragraphs The problem is usually the time is not long enough for the repair to be forgotten and thought to be paid for or what have you.
  9. rjparker
    8,123
    4,812
    I would probably add more a little at a time to clear or mostly clear the sight glass. The car does have a txv metering device before the evaporator which can compensate for some charge error.
    vallesj likes this.
  10. ChapmanF
    15,892
    Prii use subcooling condensers, which puts the proper charge at a certain extra weight of refrigerant beyond where all bubbles are cleared from the sight glass. Charging only until the glass is "clear or mostly clear" would be a guaranteed undercharge.
  11. Tombukt2
    9,667
    1,688
    Well the other way I've done it is charge it up and run the charge up until the compressor almost stumbles and then eject two squirts And generally I do this when it's 100° out 97 right at it Not in the '80s seems to work very well and all of my vehicles are ice cold just short of blowing snowflakes out the vent with my 74 Corolla with the Denso hangn0n and Tecumseh style compressor from Toyota in 74 tweaking the idle amplifier and whatnot I could make snowflakes come out of those vents no kidding r12.
