No voltage measured across "12V" battery after recharging
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gdowdy3, Sep 1, 2024 at 1:17 PM.
  1. gdowdy3
    gdowdy3 New Member
    Hello folks,
    Last weekend, I tried to use my Prius after it sat idle for a month and a half. However, I found that the car was utterly unresponsive: the door locks wouldn't work, the ignition button did nothing, no dash lights, and so on. I thought that the "12V" battery might be dead as a result of the prolonged period of inactivity. I tried to measure the voltage across this battery with my voltmeter. It reported no voltage.
    So, I tried to charge my battery with a "DieHard 71219 6/12V Shelf Smart Battery Charger". The charger showed that it was charging for about 2 hours, then declared the battery to be fully charged. However, still the car is unresponsive. Furthermore, when I try to measure the voltage across the terminals of the battery, I am again seeing 0 V.
    The battery is pretty new. I bought just late last year. Furthermore, I bought it from a local Toyota dealer, so it's not like it's some sketchy off-brand.
    Anyone have any analysis of the situation? Do I just have a bad battery? Are there any other tests you recommend before coming to this conclusion?
    Feel free to ask follow-up questions. I'm happy to provide additional details that might help you diagnose the problem.
    Garrett
  2. ChapmanF
    15,902
    Sounds like the month and a half without charge has done in the battery.
    If it was from a Toyota dealer late last year, you may be eligible for at least a pro rata and possibly full price toward a replacement if you take it back to them. Before covering it, they will put it on their own tester to see if it's really kaput.
    Brian1954 likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,540
    1,613
    NJ-USA
    I would check that your meter actually reads (DC) voltage correctly.
    Many "smart chargers" won't work correctly if the target battery is completely dead.
  4. rjparker
    8,133
    4,819
    Agree. Also make sure your voltmeter is not on AC. It will read zero dc in that mode no matter what. Simply check a 1.5 or 9v battery that you have in a drawer or a remote.
  5. gdowdy3
    gdowdy3 New Member
    Thanks for weighing in, guys!
    Fortunately, my wife has a Prius with a working "12V" battery, which allows me to take comparative measurements. If I try to measure the voltage of her "12V" battery with the same voltmeter, it reads 12.4 V, and also reports "DC". So I don't think my voltmeter is the problem.
