Driving in Charge Mode and mpg
Discussion in 'Prime Fuel Economy & EV Range' started by Robert21PrimeLTD, Aug 31, 2024 at 4:43 PM.
  1. Robert21PrimeLTD
    Robert21PrimeLTD Junior Member
    52
    24
    Nashville
    I charge my plug-in at home to a full charge and drive in ECO Mode. I go approx. 25 miles on the traction battery before the ICE turns on.
    My question is, if I switch the drive mode to CHARGE Mode so that the ICE charges the HV while driving will my overall mpg decrease? Logic says that it will. I don't drive enough miles to test it in a timely manner.
    Does anyone have experience with Charge Mode?
    Louis19 likes this.
  2. Louis19
    Louis19 Active Member
    382
    342
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Charge mode will decrease your overall mpg , ICE will work harder accomplishing 2 tasks meanning propulsion of the car and charging the traction battery simultanously . Charge mode will not happen over 80% of traction battery charge level.If you need a quick charge to 80% , charge mode will get you there more rapidly
    than L1 or Level 2 charging ....
    I use it to burn aging old gas before it gets stale, mind you I use one tank per season.;)
    For my usage , when I need gas , I go for half a tank , unless I need to go for a long trip.
    #2 Louis19, Sep 1, 2024 at 8:21 AM
  3. Robert21PrimeLTD
    52
    24
    Nashville
    Wow, one tank per season. I've been using 1 tank per 1,500 miles. I do like your 1/2 tank idea. Thanks for your insight.
    Louis19 and bisco like this.
  4. bisco
    49,725
    It will certainly reduce mpgs, but idk if anyone has calculated it
    Louis19 likes this.
