Multiple dash lights staying on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LRW, Sep 1, 2024.
  1. LRW
    LRW Junior Member
    Oak Park, IL USA
    I have a 2012 Prius V.
    Multiple lights stay on when it is started (see photo).
    I recently replaced the 12 Volt battery.
    The brakes and tire pressure were checked are OK.
    Any idea what is going on here?
    Thanks in advance for any advice.
  2. Brian1954
    Brian1954 Senior Member
    2,304
    920
    South Central PA, USA
  3. ChapmanF
    18,316
    Alternatively, if you do not have ready access to scan tool, I believe this method will show you what the codes are, for the skiddy-car, ((!)), ABS, and tire pressure lights that you have:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    The "MAINT REQD" light is strictly a miles-based reminder to get your oil changed.
    A scan tool is more convenient and can show more information, but the blink method can at least tell you what your car is complaining about, while you haven't yet picked out a scan tool.
    MAX2 likes this.
  4. Tombukt2
    13,117
    2,355
    Without getting the codes it's tricky but it looks like you maybe getting started on the brake problems. The parking brake is not set in this picture? Once that red brake light starts going on and it's not the brake pedal depressed the emergency brake pedal depressed that is yeah. No beeping yet? Car drives and runs? Car drives and runs?
  5. LRW
    LRW Junior Member
    Oak Park, IL USA
    The parking brake is not set. I even tried setting and unsetting it a couple of times and doing this does not change the dash lights. The car does start and run.
  6. Tombukt2
    13,117
    2,355
    And if you drive it up and down your street do the brakes feel any different than they did yesterday or the day before or before the lights were on? Just curious.
  7. Mendel Leisk
    41,644
    Do you have anything constantly plugged into OBD port, weighing on it?
    Have you driven it thus? If so, anything feel off?
  8. LRW
    LRW Junior Member
    Oak Park, IL USA
    My daughter is the main driver. I will ask her.
  9. LRW
    LRW Junior Member
    Oak Park, IL USA
    Nothing is plugged into the OBD port. I am not the usual driver but I will ask my daughter.
  10. ChapmanF
    18,316
