2009 Prius 220k WIX 51516
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bobodaclown, Sep 2, 2024 at 3:01 PM.
  1. bobodaclown
    bobodaclown Member
    215
    71
    Hello All,
    My Prius is at 220k, getting approx. 41 MPG with normal Michelin tires. I change me oil every 5k, current flavor is Quaker State Ultimate 5w30.
    I've been getting most parts from Rock Auto.
    My current running on oil filters is WIX 51516. A bit larger than stock but fits well in the space provided.
    Overall I believe it is a quality filter. Anti-Drain back valve was still soft and flexible after 5k, metal end caps, spring loaded bypass valve, no cardboard.
    Here's some pictures of the filter cut open.
    IMG_20240902_112820538.jpg 1000004461.jpg 1000004463.jpg 1000004462.jpg 1000004465.jpg 1000004466.jpg 1000004470.jpg 1000004473.jpg
    Hope this helps others.
