Rattling sound on Gas / Engine
Discussion in 'Prius v Technical Discussion' started by Priusdriver265, Sep 2, 2024.
Tags:
  1. Priusdriver265
    Priusdriver265 New Member
    Pakistan
    2013 Prius Alpha
    I have Prius Alpha (Prius V or C) 2013. I hear a rattling sound coming from engine / transmission area. The sound only comes driving on petrol / gas while the car is on low RPM. On EV mode, there is no sound. I got the spark plugs checked, air filter changed, fuel filter, air filter, throttle body, injectors and EGR cleaned but the sound is still there. The transmission oil has 30k kms on it and is still maroon with not metallic particles (as per the mechanic).
    What could it be?
  2. Priusdriver265
    Pakistan
    2013 Prius Alpha
    Even got the catalytic converter cleaned.
  3. rjparker
    10,413
    6,521
    Head gasket leak causing misfires
  4. vand8
    vand8 Junior Member
    37
    24
    NY
    2015 Prius v wagon
    If it always occurs when the engine is on at low rpm, then it could be a heat shield. I've had some heat shield mounting points on my Prius v and my Pontiac Vibe (Corolla underpinnings) rust out, which would then result in the heat shields rattling since they were no longer firmly mounted. Always heard at low rpm as noted. So I would check the heat shields first.
    Air_Boss and bisco like this.
