New EGR Cooler Coolant Tip - milk jugs and plastic bottles
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gboss, Aug 17, 2024.
  1. gboss
    gboss Member
    115
    Mountain Town in CA
    The good news: I found a simple Prius-dogma way to drain the coolant without going down to the radiator spigot or spilling everything into the engine.
    The bad news: I dropped a 12mm socket and the metal gasket w/ clip between the EGR cooler / engine. I can't see them and have no idea how to retrieve them from the bottom of the engine bay. I'm pretty sure they dropped to the bottom...this is disaster.
    EGR coolant tip:
    1. Get yourself an empty milk jug (or 2L soda bottle) and a few plastic water bottles.
    2. Cut the tops off of each bottle
    3. Find the small coolant tube coming out of the throttle bottle to the EGR cooler
    4. Hold the large bottle with cutoff top next to it
    5. Disconnect the tube and swing it ontop of the large bottle...let it drain
    6. Use the small plastic water bottles in the same fashion for the other lines (these bottles are smaller and fit in the tighter spaces). Most of the coolant has been drained already so there won't be much left in the other lines.
    7. Empty the large jug and any small bottles into a stock water bottle for storage so you can pour it back later.
    This worked out really well for me and didn't leave any spills. You can also see how much coolant was stored in the EGR coolant area - about 15oz. I've got my cooler sitting in Mendel's suggested oxyclean solution in a bucket and hope to blast it out tomorrow with a pressure washer.
  2. Tombukt2
    9,707
    1,697
    Just put another 12 mm nut stud bolt whatever it is you dropped and be done with it it's probably going to fall out onto the ground I'm assuming all your plastic is sitting under there and you have your little oil door and insulation and everything is real pretty so you can pull all that down and you can get under the car and smack on it and maybe the bolt nut or stud is sitting down there and you'll hear it rattling around you'll never get it to fall out but you'll know it's there and or you can remove all that plastic and pull down on it and just form it to find this little bolt. Every time I get one of these cars over here there's a few little bolts and nuts hanging out in those plastic pieces A lot of times those plastic pieces are hanging and all fubar I remove them take pictures of them for the customer showing the crap that's come out of them and then tell him he can go buy new ones or whatever and we can put all that stuff back up pretty or given the condition of the car he can forget it and let it rip his choice totally they usually go in the trash.
  3. gboss
    gboss Member
    115
    Mountain Town in CA
    Yeah, next step is to remove the entire panel. It was the actual socket from the wrench that fell down into the bay...hoping it doesn't hit any of the electric motor moving parts if I can't find it.
    Might as well change coolant, invert coolant, and transaxle while I’m down there.
    #3 gboss, Aug 18, 2024
    Brian1954 likes this.
  4. Mendel Leisk
    38,894
    I see your table lamp:
    And raise you a floor lamp:
    Read 'em and weep:
    gboss likes this.
  5. gboss
    gboss Member
    115
    Mountain Town in CA
    You got me @Mendel Leisk , too rich for my blood! Cake too...now you're just showing off - I'm trying not burst a blood vessel during this tedious operation.
    Finally got things back together but haven't turned it on yet. I thought I caught most of the coolant but I guess the small amount I spilled was wayy more than I thought..not sure how:
    I'm going to replace spark plugs while I have the cowl off and then test it. Do you think it's okay to test the engine on this amount of coolant at idle and maybe a short drive? /forgot to leave the top EGR hose disconnected when refilling but will let is sit overnight and hopefully it makes its way through ...we really need to a make sticky with all the small steps
    Also, I just read about someone taking their car to the stealership to upgrade the cooling pump logic in the ECU via a TSB after doing the EGR circuit? I'm lost, is that required for this too?
    #5 gboss, Sep 1, 2024 at 9:18 PM
  6. Mendel Leisk
    38,894
    Never heard of that.
    Is there ANY coolant in that reservoir? I’d be inclined to score a gallon of Toyota Super Long Life, top it up before driving.
    that was pumpkin pie, made with Halloween pumpkins no less, that’d been lurking in the freezer for at least a year. :)
  7. gboss
    gboss Member
    115
    Mountain Town in CA
    I’ve got 2 gallons of coolant, ready to go to do the flush on the inverter and the engine. Along with transmission fluid. I just thought I’d try to start the car up and make sure no codes start flying if I did something wrong with the EGR circuit and spark plugs.
    Still confused why that coolant is so low (it was already at the low mark when I started the circuit) as I thought I caught nearly all of it .
  8. Mendel Leisk
    38,894
    Explain "caught".
    Did you do a preemptive 2 quart drain (from the radiator drain spigot), prior to pulling the cooler hoses? This'll leave the EGR components more-or-less dry.
    Did you leave the throttle body coolant hoses connected? They have enough slack that you can pull the TB off the intake manifold, tie it too the inverter cables.
    More info on both the above in top link in my signature (on a phone turn it landscape to see signatures).
  9. bisco
    49,729
    i think @ChapmanF had the pump software updated iirc
    gboss likes this.
  10. gboss
    gboss Member
    115
    Mountain Town in CA
    Yup, I drained the 2 quarts in the new method I described in my OP (I used a fuel line clamp on the hose running from the EGR cooler to the throttle body after moving it out of the way from the intake manifold....same method as going for the radiator spigot but without having to get under the vehicle). There was some slight spillage when one of the clamped coolant lines I had tied up high fell below the cooler, but it was a small puddle...or so I thought.
    Also, if anyone is interested...this is what my spark plugs looked like after 110,00k miles and a clogged EGR (new one on bottom for comparison):
