  1. Arthurwg
    Arthurwg Junior Member
    Taos, NM
    I bought my 2015 Prius used from a Toyota dealer. After driving about 80,000 miles I had a flat, only to discover that my car did not have a spare, jack or wrench! I guess I should have looked for that when I bought it, but somehow I assumed the car would come with that equipment. I called the dealer to complain only to find that the dealership had changed hands and they were not interested. Anyway, now I'm faced with replacing the spare and tools. So what do I need? A doughnut, jack and wrench? Any suggestions where I might find that used?
  2. Arthurwg
    Taos, NM
    As an alternative to the Donut, I'm wondering if a full-size spare will fit into the compartment in the trunk. Also, what kind of a jack do I need? Thanks for the help.
  3. bisco
    49,729
    you could try ebay, or if there are any salvage yards nearby. there should be no shortage of junked prius. i don't think full size will fit, but i could be wrong.
    you should be able to get all the part numbers and specs from a dealer parts department.
    it's just a standard scissors jack, but you couldn't go wrong if you can find a descent aftermarket, the oem is pretty flimsy.
    i hink you jack on the pinch weld under the rockers, it should be in your owners manual.
  4. Mendel Leisk
    38,895
  5. AzusaPrius
    AzusaPrius Senior Member
    1,986
    848
