  1. AzusaPrius
    AzusaPrius Senior Member
    1,986
    848
    Labor day a good day for a power outage!!
    First noticed the power cutting in and out a couple times around 2am and then it was out at 3am until 8pm.
    Got out a little power source and quickly connected it to the 12v and started to run extention cords through out the house.
    This was around 10am and just connected a stand up fan at first, then the refrigerator and then another stand up fan, then two lamps
    This was all connected once the ICE got to two bars and started charging, I had just the one stand up fan connected when the HV battery was almost full and it took a long time to get to two bars with just one fan connected.
    It was hot outside today and the temp inside the house got to 95F
    Once the battery drained to two bars and the ICE turned on to charge to three bars, I paid attention to how long the battery lasted until the next recharge.
    With just the one stand up fan using about 50watts it lasted 40 minutes until it charged again.
    Once the refrigerator was hooked up, I checked how much just the refrigerator was using and it was 142watts.
    Then pluged the fan back on and it went to 185watts and I ended up getting to just over 200watts with both fans, the refrigerator and two lamps later on.
    Once all those things were connected, the ICE would kick on every 20 minutes like clockwork, then 3 minutes to charge to three bars then silence for 20 minutes.
    I ran this all day from 10-8pm with a solid half a tank of gas, it did not even drop a bar.
    I love how quiet it is to run the Prius as a generator versus hearing my neighbors run their loud generators.
    Some pictures of the day below.
    The ICE starts to charge at 42.26 SOC
    For 3 minutes to 53.56 SOC
    What a day oh the first thing I actually tried was my espresso machine, gotta start the day right.
    20240902_113238.jpeg 20240902_113244.jpeg 20240902_113440.jpeg 20240902_113444.jpeg 20240902_113736.jpeg 20240902_113921.jpeg 20240902_113938.jpeg 20240902_120954.jpeg 20240902_120959.jpeg 20240902_121206.jpeg 20240902_121210.jpeg 20240902_131300.jpeg 20240902_140451.jpeg
  2. MAX2
    MAX2 Member
    200
    44
    Third Rock from the Sun
    How do you rate the efficiency of your "Prius generator"?
    The amount of fuel consumed per unit of power of the received electricity?
  3. AzusaPrius
    1,986
    848
    10 out of 10 stars for running over 10 hours and not even dropping a bar on the fuel gauge.
  4. MAX2
    MAX2 Member
    200
    44
    Anything that has physical parameters can be measured not only in stars, but also, for example, in quarts, pints, ounces or watts))
  5. AzusaPrius
    1,986
    848
    All together the ICE ran a total of about 90 minutes for the 10 hours and maybe used 20-30 miles tops on the DTE.
    #5 AzusaPrius, Sep 3, 2024 at 1:30 AM
  6. MAX2
    MAX2 Member
    200
    44
    It is possible to use the following method.
    Fill the fuel to the top of the filler cap.
    Using an energy meter calibrated in watt-hours, determine the amount of energy transferred from the "prius generator" to the house over a certain period of time.
    Then add fuel again with a precisely measured container to the level of the filler cap and find out what volume was used to reproduce the required amount of electricity.
    By weight, combustion of gasoline releases about 46.7megajoules per kilogramm (13.0 kWh/kg; 21.2 MJ/lb) or by volume 33.6 megajoules per liter (9.3 kWh/L; 127 MJ/U.S. gal; 121,000 BTU/U.S. gal)
  7. AzusaPrius
    1,986
    848
    For simplicity we will say I used 2,000 watts in 10 hours for less than 1 gallon of fuel.
  8. MAX2
    MAX2 Member
    200
    44
    There is approximately 35,461 watts of heat energy hidden in 1 gallon of gasoline.
    2,000 watts produced.
    5.6% efficiency
