Hybrid fan cleaning
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by DKCK, Sep 3, 2024 at 8:03 PM.
  1. DKCK
    DKCK New Member
    Yesterday
    Maryland
    Greetings all,
    We have a 2012 Prius V, about 88,000 miles. No problems whatsoever with it since we got it. We recently had a routine oil change at a dealer and they recommended a hybrid fan cleaning. We've never had this recommendation before, and to my knowledge it has never been done. They want ~$180 for it. From online videos, it looks like you have to remove the back seats and do other things to get the job done. It seems more effort and time than I'm willing to commit myself. Do I really need to get this done, or is it basically make-work for the dealer's service department? Thank you for any advice you can provide.
  2. MAX2
    MAX2 Member
    222
    Third Rock from the Sun
    You can easily do it yourself. The grille can be removed and cleaned. Access to the fan and high-voltage battery from the trunk is also simple.
    Air_Boss likes this.
  3. OptimalPrime
    OptimalPrime Member
    123
    79
    Keene/Nashua
    If you have pets in the car, you should bother to replace all the battery air inlet filters and maybe clean the blower. If you don't have pets and aren't in a dusty environment, I'd just deal with the filters. In any case, checking and replacing the filters will give you an idea of whether there is stuff even available in your car to clog the filter, then stuff bypassing the filter can get to the blower. If your filters are clean, so is the blower, most likely. Unless the filters were replaced since they were clogged, such as if you had a dog but no longer do, or bought a pet car from someone who changed the filters to hide that fact.
  4. rjparker
    8,149
    4,828
    First a v has many advantages and one is access to the battery fan. One 10 mm bolt is all it takes because the world’s best taxi has sliding back seats. There is no need to remove back seats or side panels either.
    On the downside, there is no fan filter and the intake is under the rear passenger seat unlike the hatchback. Does not matter as you will soon see.
    Merv does it while his buddy is delivering fertilizer.
    Don’t worry about the 12v battery cranking the engine joke. You had to be there. It’s not necessary to pull the orange plug either because you don’t need to remove the hybrid battery cover. He’s just covering his behind hoping you will be around to buy his merch.
    #4 rjparker, Sep 4, 2024 at 1:19 AM
  5. Mendel Leisk
    38,899
    Even on the 3rd Gen hatchback there’s no need to pull the rear seat bottom. I wish NutzAboutBolts would add a disclaimer to their video. There’s one bolt (12 mm socket size IIRC) below intake grill, in behind the seat cushions, but the gap between seat bottom and back is enough you can sneak an extension through, and get fingers on the bolt to catch it.
    also, the fan can be cleaned without removal; you just need to get to it, pull off the associated ductwork (run a duster boa through those ducts too). A Q-Tip works good on the fan fins. Some sort of compressed air is handy too, even just a vacuum on blow, or leaf blower.
