Hybrid Battery Mounting Bolts
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by anonymous, Apr 11, 2024.
  1. anonymous
    anonymous Member
    177
    98
    US
    Which one goes where?
  2. Tombukt2
    9,730
    1,699
    Usually the silver ones with the silver washer go in the brackets that hold the battery down and keep it moving from side to side two of them hold each bracket to the frame of the car and then two or three of the silver 12s go right behind the seat on top of the battery in the threaded holes that you can see in the battery case It really doesn't matter but whatever you think I can take a picture of a battery mounted reasonably properly and you can see where the silver screws go I think they're all so silver where they go on the battery case to the floor of the frame of the car. And then of course the 10 mm ones hold the case halves together.
  3. PriusCamper
    PriusCamper Senior Member
    11,210
    4,567
    Pacific Northwest, USA
    You're lucky it's not a gen2 Prius... There's 12 bolts for the 4 that holds down pack in Gen3... And it doesn't really matter that much as long as the bolts holding down the seat belts and their brackets don't get confused.
  4. Tombukt2
    9,730
    1,699
    If you're playing whack-a-mole and you're going to be whipping the battery in and out a few times because you've got more time than money You want to trim your brackets and carefully place bolts only where you need them so that you can whip the battery out again the next time in like 22 minutes instead of the 48 or so it took initially I have mine set up in the generation too so that I can literally take the bolts out of the top of the bracket wings that are mounted to the inside quarter panel frame of the car and just lift up on them with my hands they bend and then undo three bolts or so that are literally holding the battery down to the frame of the car Don't have to get behind the back seat backs or bottoms or any of that those bolts aren't there there's one bolt in the center at the rear going to the floor of the trunk and the two on the edge right above the spare tire holding the battery down to the frame of the car and then the two bolts the 8 mm that are holding the orange wires under the front end of the battery and then I'm turning the battery sideways and sliding it up a little ramp I've made out of plywood right out the back of the car One handed one person right now this is in the generation two The three is a little easier. Nope the car can land upside down in an accident and the battery still won't come loose from being mounted this way how do I know I had a battery junk battery mounted this way in the junk Prius that I picked up with a forklift at the junkyard flip the car over and dropped it off to forklift from 12 ft in the air smash the roof screwed up the tailgate battery or anything in the car didn't budge few pieces of plastic then we went to lunch.
  5. Mendel Leisk
    38,903
    Classic (y)
  6. PriusCamper
    11,210
    4,567
    There's lots of aftermarket battery installers that don't use all the bolts... I'm constantly running out of 12mm bolts because when I work on Prius I do it right and use all the bolts no matter what because that's how it was designed. And Gen3's design takes way less time than Gen2 in terms of bolts.
    Carall and Tombukt2 like this.
  7. Tombukt2
    9,730
    1,699
    Well if you're playing whack them all you just want a few bolts in so you can whip the thing in and out the three or four times that you're going to probably have to do this while you learn to play the game and then after that you can lock it down in there with loctite if you want but three bolts in the battery and two in the wing covers hells from a 12-ft drop of near 4,000 lb vehicle so I think we're in there pretty good.
  8. PriusCamper
    11,210
    4,567
    I'd rather do it right the first time... There's more than a dozen ways to find a bad module before you put the pack back in.
  9. Has Raf
    Has Raf Junior Member
    30
    Stoke-on-Trent, England
    I need to order these silver bolts. Anyone got a link? I’m in the UK. Or do you have the specs for them, then I can search for them here. Thanks.
  10. Mendel Leisk
    38,903
    Are you not close to a Toyota dealership? Their parts department should be able to sort it out.
  11. Has Raf
    30
    Toyota parts direct from the dealer are expensive. They wanted charge me £170 for a lower engine mount, when I can get one for £20-30 from a decent brand company.
  12. Mendel Leisk
    38,903
    A phone call is free, they give you a part number and a price. For a bolt, if it's 2~3 pounds, I'd go for it.
  13. PriusCamper
    11,210
    4,567
    I get 'em off junk Prius at wrecking yards and from rebuilders, but I need a source to buy them from in the US. Have never found someone selling them. Anyone got any links for them?
  14. Tombukt2
    9,730
    1,699
    What machine screws are you looking The 56 or 58 on the bottom that hold the modules to the battery tray or something else I would think that would not be a problem to source at all You don't need to buy new ones or they're not special I mean there's nothing special about him matter of fact if you could get them in plastic that would be kind of kick nice person then they couldn't ground to the tray The acid would be touching a plastic threaded dowel attached to the head of that plastic dial which is also plastic and so it won't leak and when it does break through the thin plastic it's not touching metal so nothing happens
  15. Mendel Leisk
    38,903
    ^ Yeah same question. Not clear what bolts. Somehow I had it in my head it was these, not sure why:
    (FWIW, they're M6x14)
    #15 Mendel Leisk, Sep 4, 2024 at 2:23 PM
  16. Has Raf
    30
    I’m talking about the bolts right at the beginning of the thread. The ones OP’s talking about. The ones that hold the metal panels on the left and right side on top of the hybrid battery casing. IMG_2465.jpeg
