Vsc light on, Master triangle on & can't accelerate!
Discussion in 'Gen 3 Prius Technical Discussion' started by Prius.Lover, Sep 3, 2024 at 7:25 PM.
  1. Prius.Lover
    Prius.Lover New Member
    Yesterday
    United Kingdom
    Good day, please forgive me if I am posting this on the wrong discussion group or if this has been discussed already - I did look through the forum but couldn't find my exact problem. Any support would be greatly appreciated!!!
    Basically, my car was parked in a long stay car park for 7 weeks and when we tried to start it, it wouldn't comply. Airport worker jump started the car and initially it drove okay. Less than 30 mins into the drive, the red triangle with exclamation mark, orange circle light with exclamation mark and the vsc engine light came on.
    Pulled over, called out AA who did a diagnostic check and said nothing major was wrong, cleared the faults and said it was likely that the battery didn't like the abrupt jump start. It apparently should have been slowly charged before the high intensity jumpstart..?
    Anyhow, before we even left the service station, the lights came back on and I started noticing that when accelerating I was getting major resistance. It sounded like I was over revving the engine. I had to put my hazards on a few times because I couldn't accelerate enough to keep up with traffic!!!!??
    Also usually when I drive at speed, the battery charges up and you can see it full on the touchscreen screen. Not this time- it slowly drained to two bars. And a red car shaped light with an exclamation mark came on for the trip.
    Finally made it home after almost 7 hours (journey should have been less than 3).
    Any idea what this could be? Husband mentioned the mass air flow sensor may be faulty hence the acceleration issues. Or the 12v battery needs replacement?
  2. MAX2
    MAX2 Member
    222
    51
    Third Rock from the Sun
    Long-term parking is not very good.
    The high-voltage battery modules can discharge.
    Self-discharge varies for different modules and when one has dropped significantly in voltage, the others may remain normal.
    When operating a hybrid system, these differences in the voltage of neighboring modules can cause a red triangle and failure messages.
    To answer your questions accurately, we need some data on the error codes.
    Do you or your husband have the opportunity to find a scanner to read the codes?
    Prius.Lover likes this.
  3. Tombukt2
    9,730
    1,699
    The easy over revving of your engine is the clue your electric motors aren't meshing well with your gas engine and the engine rev sound happens like the clutch is slipping your clutch is your electric motor if you will and when it can't actively participate like it wants to your engine will outreve your electric motor I guess is what I'm looking to say kind of happened on my '09 and when this started to happen the traction battery was going into the toilet quickly. After changing the battery for a new one that problem went away forever. Then I got another '07 car drove that for a while still have the '09 '07 started doing the same thing same problem traction battery just not up to snuff fix that all that revving and slipping vanished The red car on your MFD could be telling you that you're not getting adequate charging because your inverter pump is not working or up to snuff but even if you're charging near end of life battery like crazy you can still get the slipping and the over revving so you may have a compound set of problems in that case
  4. ASRDogman
    ASRDogman Senior Member
    6,210
    3,324
    aaa doesn't know anything about hybrid cars.
    There is no power surge when jumping the 12v battery.
    How old is the 12v battery? You could charge it for 6 or more hours at
    5 amps or less. Remove the charger and check the voltage about 30 minutes later.
    It should read 12.6 or more. Anything less it's marginal. If the battery is older than 6 years,
    it probably time to replace it.
    Is the hybrid battery the original for your 2012 Prius? It could be getting weak.
    You can use a proper hybrid code reader and clear all the codes. Start the car and just
    let it idle and charge up the battery. With no heavy load it "may" charge up the battery and
    balance out the blocks some.
    It probably wouldn't hurt to get the Prolong system, or one similar, and run the hybrid battery
    through the complete cycles to bring some life back to the hybrid battery. It worked for me for
    about 3 years.
    Even if you just got the charger you could charge it for several hour after it levels out to balance
    all the blocks.
    You also need to check the inverter coolant pump, it might be failing and not circulating the coolant
    and causing the inverter to over heat. And also check the inverter because it might have failed.
    If you can't do these checks yourself, you should take it to a place they works with hybrid cars.
    And a Prius specialist would be best...
  5. bisco
    49,739
    lights on the dash mean that there are trouble codes that can be read at the dealer or a qualified hybrid mechanic with a prius aware code reader.
    these codes will point the way to the fault(s) and we can help with diagnosis and repair if you post them here.
