  1. Jason Packel
    Jason Packel Junior Member
    51
    Orlando, Fl
    Codes just showed that I need to replace my inverter pump, can I last three weeks with a little driving before doing in? Thanks so much.
  2. Tombukt2
    9,740
    1,702
    The temperature generally going down this time o Year so I would say yes unless you're beating the hell out of the car a lot of highway driving and high speed driving I've driven in North Carolina for half a year without an inverter pump without any trouble car drove impeccably the way it was used. And hopefully you're going to do this in your driveway just need a 10 mm long socket and two corks to block off the water pipes was as you pull them off and a long pair of needle nose to unplug the connector before you undo the three gold screws and withdraw the pump this is like a 30 minute operation but you can go ahead and pay whatever and do what have you want I guess.
