Prius 2006,first time owner!
Discussion in 'Gen 2 Prius Main Forum' started by Prius2006GuitarGuy, Sep 1, 2024 at 5:29 PM.
Tags:
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy New Member
    Sunday
    Sweden
    Hey guys!
    This is my first car that I bought, it's 18 years old (Prius, Gen 2, 2006) but 3 days old to me! ;)
    It's coming up to it's service time at 33500km (around 207000 miles) and going to need servicing soon.
    I don't know much about cars so I was thinking it would be a good experience to learn by doing things, I'm a DIY sort of guy and like working with my hands.
    Would appreciate it if you told me what needs to be done (self service?) and any links to help me on my way, what I can do I shall try to do,what's out of my range -I shall hand over to a pro mechanic:cool:.
    Thanks!
  2. MAX2
    MAX2 Member
    240
    52
    Third Rock from the Sun
    Check, or better yet, replace engine, transmission, and brake fluids.
    Buy an OBDII scanner. It will help with diagnostics of various systems.
  3. bisco
    49,741
    Congrats and welcome!
    Do you know any of the maintenance history of the car?
  4. Prius2006GuitarGuy
    Sunday
    Sweden
    Thanks! I was on youtube and they spoke about an obd scanner as well, just confused as to which one is good or will work withn the Prius as some say they are not hybrid combatible.
    Can you recommend any one of these (Amazon Sweden):
    amazonDOTse/s?k=obd2+scanner (remove the DOT as it won't let me post a link)
    Will look on youtube to change those fluids you mentioned. Do I also change any air filters?
    He told me it was serviced at regular intervals but I didn't get the service record, the guy was supposed to contact me after he finds it but not sure now...
  5. Brian1954
    Brian1954 Active Member
    931
    351
    South Central PA, USA
    Take a look at this thread: https://priuschat.com/index.php?posts/3290690
  6. Leadfoot J. McCoalroller
    7,251
    6,791
    Pennsylvania
    2018 Prius c
    Get a good Autel. All the cheaper ones only scan part of the car. With one that old you want to be able to diagnose the whole thing.
  7. Prius2006GuitarGuy
    Sunday
    Sweden
    How about this one?
    amazonDOTse/-/en/AL319-diagnostic-vehicles-real-time-definition/dp/B01M2WTO2K/
    (remove the DOT from the above Amazon URL)
  8. dolj
    dolj Senior Member
    7,764
    3,932
    Wellington, New Zealand
    No.
    Try Autel AP200.
  9. bisco
    49,741
    Most readers don’t play nicely with Prius due to the complexity of the ecu system
  10. MAX2
    MAX2 Member
    240
    52
    Read here, everything is written in detail about OBD-II
    Hybrid Assistant: OBD
  11. Brian1954
    931
    351
    The link you provided discusses OBD2 adapters that work well for the Hybrid Assistant app. What the OP needs is an OBD2 adapter (like the Autel AP200) that can communicate with all the different ECUs in a Prius and read the trouble codes that have been activated. When the OP does have problems with the Prius, a scan tool will be needed to read the trouble codes. See post # 5.
    #11 Brian1954, Sep 4, 2024 at 9:15 AM
  12. MAX2
    MAX2 Member
    240
    52
    For more detailed diagnostics I use Techstream. This Toyota program for Toyota and Lexus cars.
    For daily monitoring of parameters I only need an OBD-II connector and an Android phone.
    If Autel AP200 helps someone, then that's good.
    All that remains is to compare the economy.
    For the first option you need a connection cable + laptop.
    For the second, an OBDII scanner + phone.
