Bleeding brakes from 2012 Prius with pneumatic bleeder
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ryan Gallo, Sep 3, 2024.
  1. Ryan Gallo
    Ryan Gallo Junior Member
    Seattle
    I’m replacing the brake pads and rotors on my 2012 Prius and am going to bleed the brake fluid as well. I purchased a pneumatic brake bleeder from Amazon, linked below, and was wondering if this can be safely used on both the front and back brakes as long as I first put the Prius into INVALID mode?
    I’m mostly worried about the back brakes as I know they have the electronic pump system.
    And I won’t need a friend, right?
    Bleeder:
    EWK 23 Pcs 2L Pneumatic Vacuum Brake Fluid Bleeder Extractor Pump Kit + 1L Refilling Bottle
  2. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    You don't need this.
    Brake bleeding is done by the Prius itself. It re-pressurizes the system with a slight pressure leak.
  3. Ryan Gallo
    Seattle
    Sorry, I got my terminology mixed up. I’m looking to flush my brake fluid. Not bleed them. Would this kit work well, on the back brakes too?
  4. Mendel Leisk
    42,060
    I’ve done a couple of brake fluid replacements so far, using the non-Techstream method (proscribed in Repair Manual). My tools were very rudimentary, no external vacuum used, apart from a baster to initially extract/replace reservoir fluid.
    when doing brakes, specifically when retracting caliper pistons for new pads, I’ve never opened bleed screws, and never had subsequent problems. Brake fluid replacement is worthwhile, but I would leave it for another day, and be careful to do it by the book.
    there’s links in my signature, one for brake fluid change, the other about rear brake drag; both have relevant info. (On a phone turn it landscape to see signatures).
  5. Ryan Gallo
    Seattle
    Thanks all. The wheels are off, so I’d really like to flush the brake fluid now. I really just need to know whether it will be safe to use the vacuum pump on all calipers, so long as the car is in invalid mode.
    I read somewhere that failing to put it into invalid mode and trying to flush the brakes could damage the electronic braking system for the rear wheels.
  6. Mendel Leisk
    42,060
    Guess I’m saying you don’t have to use suction. OTOH NutzAboutBolts did, in their video.
  7. Ryan Gallo
    Seattle
    @Mendel Leisk - Another related question: would it be safe to use the pneumatic vacuum pump on the rear brakes without putting the car into invalid mode - and only disconnecting the 12v battery?
    I've replaced the rotors and pads and the car is still up on jackstands. I would like to avoid turning the car on at all, since I've heard brake fluid sediment from the calipers (which had to be pushed into accommodate the thicker brake pads) could recirculate through the system and cause problems. Now is the time to flush, I figure, but I'd like to do it without powering anything back on.
    I just want to make sure I'm not going to damage the electronic pump by sucking from the rear calipers while its completely off.
  8. ASRDogman
    ASRDogman Senior Member
    7,909
    4,020
    Yes, you can use a vacuum pump. And if you open the bleeder screw while you screw the
    pucks back in the fluid likely go out the bleeder screw... path of least resistance...
  9. Ryan Gallo
    Seattle
    Thanks - so:
    * car off (native terminal disconnected)
    * not in invalid mode (obviously, it’s off)
    * normal brake flush routine with vacuum pump
  10. Mendel Leisk
    42,060
    I would save the brake fluid for another day, and do it by the book. Bleeding the rear brakes is a walk-in-the-park by the proper method: if you've got someone pressing the brake pedal the rears will continuously pump out fluid, without suction, just a tube pushed over the bleed screw, crack it open, run it to something to catch it. Do close the bleed screw BEFORE assistant releases brake pedal.
    Again, I've been changing brake pads for decades, never touched the bleed screws at the same time.
    There's a link in my signature on rear brakes: you want to be careful with the caliper piston orientation, and ensure it doesn't have a chance to rotate, till you've firmed up the brake pedal. Then take a short drive and test. More info in the link.
  11. Ryan Gallo
    Seattle
    I’ve heeded the advice of @Mendel Leisk and will flush the brakes on another day. Or pay a shop to do it. Thanks!
  12. ASRDogman
    7,909
    4,020
    ??? Seriously?
    It's a very simple thing to do.
    Get all 4 wheels off the ground on jacks stands, then remove the wheels. It makes it a lot
    easier and faster.
    Suck out as much of the fluid from the reservoir. Open one of the rear bleeder screws, well,
    after you've connected the hose with the one way check valve, then open the front door.
    The motor will come on and pressurize the brakes, after about 5 seconds close the valve.
    Check the reservoir, fill as needed. Repeat, this time just touch the brake pedal until it starts
    pumping brake fluid. Reapeat until the fliud is clear. Close the valve, repeat on the other side.
    Do not let the reservoir go dry!
    For the fronts, you just do them manual like any other car.
    Shouldn't take any long than a hour for the complete job.
    Grit likes this.
  13. Mendel Leisk
    42,060
    Yes, but why do it on the same day you’ve dealt with a four-corner brake job; pace yourself?
  14. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    In theory, yeah. Just did mine - lug nuts were way over-torqued from tire shop (had to hop on each lug to loosen) and then discovered two stripped bleeder bolts on my rear brakes. Good times.
    Mendel Leisk and ASRDogman like this.
