  1. Arthurwg
    Arthurwg Junior Member
    Taos, NM
    I bought my 2015 Prius used from a Toyota dealer. After driving about 80,000 miles I had a flat, only to discover that my car did not have a spare, jack or wrench! I guess I should have looked for that when I bought it, but somehow I assumed the car would come with that equipment. I called the dealer to complain only to find that the dealership had changed hands and they were not interested. Anyway, now I'm faced with replacing the spare and tools. So what do I need? A doughnut, jack and wrench? Any suggestions where I might find that used?
  2. Arthurwg
    Taos, NM
    As an alternative to the Donut, I'm wondering if a full-size spare will fit into the compartment in the trunk. Also, what kind of a jack do I need? Thanks for the help.
  3. bisco
    49,741
    you could try ebay, or if there are any salvage yards nearby. there should be no shortage of junked prius. i don't think full size will fit, but i could be wrong.
    you should be able to get all the part numbers and specs from a dealer parts department.
    it's just a standard scissors jack, but you couldn't go wrong if you can find a descent aftermarket, the oem is pretty flimsy.
    i hink you jack on the pinch weld under the rockers, it should be in your owners manual.
  4. Mendel Leisk
    38,906
  5. AzusaPrius
    AzusaPrius Senior Member
    2,001
    850
    amarino likes this.
  6. Mendel Leisk
    38,906
    I'd wager the hatch floor sits an inch or two higher.
  7. AzusaPrius
    2,001
    850
    What you see in the picture is how I have it, the trunk floor does not raise 1" and lays as it should.
  8. Mendel Leisk
    38,906
    With the black plastic sub-floor tray missing.
  9. AzusaPrius
    2,001
    850
    Yes as you see it without the black plastic sub-floor tray.
  10. MAX2
    MAX2 Member
    241
    52
    Third Rock from the Sun
    Size of aluminum wheel?
    Tires?
  11. AzusaPrius
    2,001
    850
    It is a an OEM 15" and tire is 195/65R15
  12. Mendel Leisk
    38,906
    OP asked a simple question in post #2.
    You shoehorned a full-size spare in there, which rides high both due to chafing the sidewall and the tire's increased width, and to compensate omitted underfloor tray and tool cradle, likely leaving the hatch floor unevenly supported.
    I've tried dropping a full size tire/rim combo in there, know what happens.
    #12 Mendel Leisk, Sep 4, 2024 at 11:24 AM
  13. bisco
    49,741
    at least we know it can be done if that satisfies your objective
  14. AzusaPrius
    2,001
    850
    No need to use a shoe horn, it was not a tight fit and has space around the tire and goes in and out very easy.
    The hatch floor has no problems staying in place as normal. I often have lots of things in the trunk with no collapse happening.
  15. Mendel Leisk
    38,906
    Well I learn something every day.
