Bleeding brakes from 2012 Prius with pneumatic bleeder
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ryan Gallo, Sep 3, 2024 at 8:19 PM.
  1. Ryan Gallo
    Ryan Gallo Junior Member
    Seattle
    I’m replacing the brake pads and rotors on my 2012 Prius and am going to bleed the brake fluid as well. I purchased a pneumatic brake bleeder from Amazon, linked below, and was wondering if this can be safely used on both the front and back brakes as long as I first put the Prius into INVALID mode?
    I’m mostly worried about the back brakes as I know they have the electronic pump system.
    And I won’t need a friend, right?
    Bleeder:
    EWK 23 Pcs 2L Pneumatic Vacuum Brake Fluid Bleeder Extractor Pump Kit + 1L Refilling Bottle
  2. MAX2
    MAX2 Member
    248
    53
    Third Rock from the Sun
    You don't need this.
    Brake bleeding is done by the Prius itself. It re-pressurizes the system with a slight pressure leak.
  3. Ryan Gallo
    Seattle
    Sorry, I got my terminology mixed up. I’m looking to flush my brake fluid. Not bleed them. Would this kit work well, on the back brakes too?
  4. Mendel Leisk
    38,907
    I’ve done a couple of brake fluid replacements so far, using the non-Techstream method (proscribed in Repair Manual). My tools were very rudimentary, no external vacuum used, apart from a baster to initially extract/replace reservoir fluid.
    when doing brakes, specifically when retracting caliper pistons for new pads, I’ve never opened bleed screws, and never had subsequent problems. Brake fluid replacement is worthwhile, but I would leave it for another day, and be careful to do it by the book.
    there’s links in my signature, one for brake fluid change, the other about rear brake drag; both have relevant info. (On a phone turn it landscape to see signatures).
  5. Ryan Gallo
    Seattle
    Thanks all. The wheels are off, so I’d really like to flush the brake fluid now. I really just need to know whether it will be safe to use the vacuum pump on all calipers, so long as the car is in invalid mode.
    I read somewhere that failing to put it into invalid mode and trying to flush the brakes could damage the electronic braking system for the rear wheels.
  6. Mendel Leisk
    38,907
    Guess I’m saying you don’t have to use suction. OTOH NutzAboutBolts did, in their video.
