Could this be the real reason why the head gasket fail?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Anklepain, Sep 4, 2024 at 10:48 AM.
  1. Anklepain
    Anklepain New Member
    Finland
    2014 Prius+ MPV
    What do you think about slightly overfilling the oil would lead to hybrid engine instant torque start pulling the oil to intake manifold? This would cause cold start, missfire and clogging. And maybe head gasket failure also?
    Me, my dad and many of my friends are type of people that thinks "more is better" in almost everything in life. I just think is this type of thinking (more is better) is usual in general?
    Is there lots of Prius owner had sligthly overfill the oil thats why there is so many head gasket failure?
    Here is the video about this topic at chapter number four at 9.08 min.
  2. Anklepain
    Finland
    2014 Prius+ MPV
    Ps. I dont have head gasket failure. Just bought my Prius V 2014 5 months ago. It run great. The service man slightly overfill the oil first time when I bought the car. Second time I slightly overfill the oil 3 weeks ago when changing oil. Im going to suck that extra oil out this week.
  3. Leadfoot J. McCoalroller
    7,254
    6,793
    Pennsylvania
    2018 Prius c
    As far as I'm concerned they fail for an adequately explained and researched reason: uneven heating and cooling.
    That's been popping head gaskets from every engine maker for 100+ years.
  4. Mendel Leisk
    38,907
    What's the miles?
    How much is slightly? How much (in mm or inch) above top mark on dipstick. Up to 1/4" I'd just let it be.
    Long shot...
  5. bisco
    49,746
    there are many instances where more is not better, and can sometimes cause pain and death
    Mr. F likes this.
  6. Anklepain
    Finland
    2014 Prius+ MPV
    140k mile. About 1-2mm above top mark. What do you mean by long shot. Did you watch the video above at 9.08 min. The car care nut said you should fill the oil slightly below top mark in hybrid cars. If you have time you can watch it. He had very good point for it.
  7. Anklepain
    Finland
    2014 Prius+ MPV
    Yes, I know more is not always better. Im just thinking, is this (more is better) behavor is usual for most of people after all. Thats why there are maybe many prius owner slightly over the oil. And that is why it would clogg their intake manifold. And that is why maybe their head gasket is blown. If you watch the video above at 9.08 min, it says slightly overfilling the oil is the BIG NO GO for the hybrid cars.
  8. ASRDogman
    ASRDogman Senior Member
    6,226
    3,326
    Depends on what you mean by slightly.....
    I put 4.5 quarts in mine. It always goes right to the bottom of the full line.
    When I put 4.75 qts in it, like it calls for, it's just over the top of the line.
    Now if you put a full quart over, that could likely be a problem.
  9. Mendel Leisk
    38,907
    That’s nothing.
    I doubt overfill is causing the head gasket failures. My theory (in case you haven’t heard) is that the carbon-clogging EGR system is the culprit.
  10. bisco
    49,746
    some think the oil should be changed at 5k intervals, others say the coolant should be changed more often or at least tested.
    toyota claims the coolant pump speed control needs updated software, and i think unlike n/a, europe got a tsb.
  11. ChapmanF
    15,934
