Gen4 Buyer’s guide? Looking at this one:
Discussion in 'Gen 4 Prius Main Forum' started by Tom(ง︡'-'︠)ง, Sep 6, 2024 at 6:26 AM.
  1. Tom(ง︡'-'︠)ง
    Today
    Belgium
    Hello, my Tom and I’m new to the forum. I live in Brussels Belgium.
    I’m looking at a 2016 gen4. Anything to look out for other than general advice?
    I get a one year warranty from the garage I’m buying from.
    I’m not yet allowed to post links.
    japcars (dot) be /fr/occasions/603/toyota-prius-hybride (dot) html
    this is the car, any advice would be great.
    i have obd 2 reader dongle and dr Prius app but I doubt they will let me check.
    The battery should be under the Toyota 10year warranty.
    Other than the heat exchanger issue above the catalictic converter, which I would not know how to check if everything is running smoothly and oil is not mayonnaise, I’m not sure what else to look at.
    thanks in advance!
    best,
    Tom Malschaert
  2. BiomedO1
    1,575
    834
    SacTown, Ca
    Welcome Tom,
    Mark the coolant level on the coolant bottle & check every 2 weeks or before and after a long drive. If you catch the problem early, you won't damage anything. If you allow the problem to persist to the point the CEL is telling you something is wrong - your risking major repair costs.
    Re: Dr Prius app & scanner; an honest shop wouldn't mind if you scan the car or they will use their own scanner to show you what you need to know. I understand why a shop wouldn't let customer's plug-in their cars - someone can really disable or damage the car if they know or don't know what they are doing - so have the shop mechanic available when you go look at the car. It will be his option to use your or his scan tool.
    Hope this helps...
    Tom(ง︡'-'︠)ง likes this.
