timing Chain
Discussion in 'Gen 2 Prius Main Forum' started by Mehmet alb, Oct 15, 2022.
  1. 16 yrs & counting
    16 yrs & counting Junior Member
    69
    22
    Oakton, VA
    As I recall, to get to the ignition coils you have to detach/remove several other things. It's not like I can just open the hood and see these connectors right?
    How does the pin get damaged? Could that have happened while changing the ignition coils?
  2. Tombukt2
    9,774
    1,706
    Actually on a generation too when you lift the hood if you're looking behind your air box you are staring at your four connectors and your four coils and the four plugs now granted taking them off and reaching them You're going to need to undo some 10 mm hold down bolts but usually you undo the plugs and withdraw all four plugs from the coils first before you start undoing the coils It's just easier that way number four is extremely difficult. But what I'm saying is is you can see that wire loom running along the edge of the valve cover in that conduit and in that plastic cover that screws down to the valve cover You have to come up with a way to get inside of that to replace one of those plugs I don't know where you're going to put the connectors should you cut the plug off You're going to need some squeeze connectors some Scotch guard connector something and they're going to stick out and stare at you like a sore thumb because that's how most people would make that repair on the fly. The person who takes all that apart picks up that whole wire loom undoes the plastic undoes the corrugated plastic makes the repair properly and puts all that back together yeah okay unless you can go further down the line and unplug that whole loom that has the four plugs plastic the corrugated piece and all that but I think that's a permanent part of the harness I don't think it just comes apart.
  3. Tombukt2
    9,774
    1,706
    Sometimes if you don't grab those plugs just right with your long curved needle nose pliers or whatever you're using I guess it could be possible I'm not sure how you'd do it maybe trying to manhandle it or something I usually people working on these or pretty aware of Toyota type connectors but sometimes you get in a hurry I guess.
  4. 16 yrs & counting
    69
    22
    Oakton, VA
    I appreciate your help, but I don't really follow this. I don't know what the loom or the corrugated piece is and without punctuation this is hard to follow.
  5. Tombukt2
    9,774
    1,706
    I think there's a gajillion pictures here online of the generation 2 with the hood up My coils are red so as soon as you lift the hood your eyes are drawn to the red on top of the valve cover oh well most are black or gray. The wire loom is the big hunk of plastic that runs right behind the coils if you will that the little plugs come out of That's the business you would have to take all apart or else use little Scotch lock connectors which would be readily visible and your eyes would be drawn right to them if you are into that sort of thing.
  6. Tombukt2
    9,774
    1,706
    Anyway at this point the car is fixed You're happy and it's not stalling. Interesting problem for sure.
  7. 16 yrs & counting
    69
    22
    Oakton, VA
    I would like to know though if they did what they said they did, ie, can these people be trusted? They said it would take an hour but if all they did is bend the pin back into place, that seems unlikely. Since they said they replaced the connector I should have asked them to save the old connector for me. But tomorrow when the sun is up I'll take a look and see if #3 looks different from the others.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    3,561
    1,626
    NJ-USA
    So, a connector is where electrical wires attach to something. A molded plastic shell holds metal terminals (for the wires) in place where they need to be.
    That plastic shell can get damaged (either heat-age or mishandling) and the terminals can move out of position.
    The thing is, on most cars, having a bad connection to one ignition coil will cause that cylinder to not fire (a "misfire"). On some Toyotas -like the Gen2 Prius- a loose coil connection CAN cause the engine to stop running.
    However, this would set codes like P0300 (or other misfire code), a P035x (ignition coil feedback) or a "low engine power" or "engine failed to start".
    NOT a P0016.
    If your car continues to run without problem, then great. We just are confused as to where that code came from.
    Regular maintenance like timely oil changes help extend the life of your car. Think of "good" diet, exercise, and not smoking. It's not a guarantee, but the statistics don't lie. Go mark your calendar.
    Car Scanner is a decent (free) app that gives you limited access to 2-3 systems on your Prius. A more capable app and device (like the Autel AP200) gives codes, data, freezeframe - INF codes, and more on all 15-16 systems.
  9. 16 yrs & counting
    69
    22
    Oakton, VA
    So I probably DO have a timing chain issue, I just haven't gotten that code again yet. If the ignition coil connector didn't cause the P0016, then it was most likely the timing chain, and that code is likely to come back.
    Are these the 4 connectors (screenshot from a video)? I don't think anything had been removed yet when this video was taken.
    #49 16 yrs & counting, Sep 7, 2024 at 6:01 AM
  10. Tombukt2
    9,774
    1,706
    This is what I was getting at that's all factory looking unmolested and untouched by well generally human hands don't belong there until. All four of mine look just like that except my daily driver has red coil so as you see when you lift the hood your eye would be drawn right to that area where those four red things are sitting because everything else in the car is black and silver and what have you yellow stickers that car doesn't look like it's been touched in that area and if it has somebody took the time to take that completely apart replace one of those connectors or what have you put the loom the corrugated wire guide and everything back together just as factory and that would take about 2 hours to do that or maybe more depending upon the skill of the person doing the work. And if you didn't have the tooling to take apart the amp type connector that houses these little metal terminals with the little stops that actually push into the plastic plug other things are going to have to happen I don't know a lot of mechanics that have those amp connector tools I have a set sitting right here and another set sitting over there and they have been very rarely ever used ever. Except when doing engine swaps putting engines that completely don't belong in vehicles that they didn't come from That's a specialty type of work that not lots of folks really do.
