HV Battery P1A101C
Discussion in 'Prime Technical Discussion' started by Spam Trash, Sep 6, 2024.
  1. Spam Trash
    Spam Trash New Member
    Rochester, NY
    2020 Prius Prime
    My car stopped dead. Many error etc. on dash. Took to Dealership. Found rodent poop and pee on Buss bar and chewed wire. Price for Fix - $20k. So I assumed they were not interested in a repair?
    Watched all the WeberAuto videos and removed the batter cover. Yes Stack 5 looks dirty and chewed.
    Safety circuit plug removed, and 12 v system disconnected.
    So how can I clean and repair in place the terminales etc. Anyone have experience?
    Rochester, NY
    51,280
    They probably didn’t want to open a can of worms, it’s impossible to know how much damage there is and you can only repair one thing at a time.
    Idk if it can be cleaned in place, but there are plenty of threads and videos on cleaning up the inside of the battery.
    That’s an interesting code, I can’t find anything on google
  3. schja01
    schja01 Senior Member
    1,821
    1,209
    Chicagoland
    2024 Prius
    Limited AWD-e
    That should be covered by your Comprehensive (damage other than collision) Car Insurance. I don't know the value of your car but I'd call my insurance agent and see what he/she says.
    Brian1954 likes this.
  4. Spam Trash
    Rochester, NY
    2020 Prius Prime
  5. Spam Trash
    Rochester, NY
    2020 Prius Prime
    With a "Salvage Title" and deductible, its not worth $20k at the Dealership.
  6. Spam Trash
    Rochester, NY
    2020 Prius Prime
    Code comes from Dealership Diagnostic report
  7. bisco
    51,280
    Maybe someone knows what it means, I can’t find it.
    Do I see corrosion?
  8. bisco
    51,280
    A salvage title means accident and repair?
  9. vvillovv
    vvillovv Senior Member
    4,318
    1,503
    NY
    If you want I can stop by and show you the docs and give a few hints on how to pull bank 5 and repair or replace. I'm at turning point
  10. Mendel Leisk
    40,718
    If you repair be sure to mesh the rodent entry points, to avoid a repeat. Assuming similar to Gen 3, the cabin air intake’s on the firewall, just below wipers/cowl, and there’s air exit ports at the rear corners in hatch, below floor.
