Prius 2006,first time owner!
Discussion in 'Gen 2 Prius Main Forum' started by Prius2006GuitarGuy, Sep 1, 2024.
Tags:
  1. MAX2
    MAX2 Member
    271
    63
    Third Rock from the Sun
    Having received the code from Autel, can you reliably determine the cause of the problem or immediately localize the search to a specific block?
    Especially without other parameters?
    Unlikely. This requires experience, knowledge and a little luck.
  2. Leadfoot J. McCoalroller
    7,252
    6,785
    Pennsylvania
    2018 Prius c
    I'm not going to challenge you on that, because I've never personally dealt with that issue.
    I have successfully used an Autel AP2500E, a cousin to the AP200, to diagnose a problem in our car. It very directly led me to the problem, a wheel bearing hub. My other OBD scanner showed no problems at all- because it had no way of interrogating the many other ECUs in this car.
    The Autel did it. It took me right to the issue, and then immediately let me clear the code after I replaced the bearing hub.
    All I'm saying is that if you're going to have a single tool to cover the car, it probably should be this Autel setup, because it is not terribly expensive, covers the whole car to the limit that onboard diagnostics can, and works with the smartphone that nearly everyone already owns.
    I have no argument against using other apps and tools and combining results from such to learn more and develop further insight- in fact I welcome it.
    And here's the thing: you can always put off the purchase until something happens. Most dealers now (fall 2024, USD) charge $180 to do the diagnostic scan you can get out of these $70 Autel setups- just to put it in perspective.
    #22 Leadfoot J. McCoalroller, Sep 6, 2024 at 2:47 AM
    Brian1954 and MAX2 like this.
  3. MAX2
    MAX2 Member
    271
    63
    Okay!
    Let's agree that everyone uses what suits them and what achieves the best results.
  4. Prius2006GuitarGuy
    Prius2006GuitarGuy New Member
    Sweden
    Thanks for the advise, was looking at jackstands just the other day!
    > everyone should own a simple, inexpensive digital multimeter.
    :ROFLMAO::D:D:D
    Saw this and laughed, that's one piece of equipment I won't need to buy or learn how to use - I work as an electrical installer, the one I have is not that simple but it does the job!
    > have you checked the spare and the jack? do you know how to change a tyre?
    Yes, and yes in theory...
    The first thing I am trying to aquire is a spotclean vacuum, the interiors need to be cleaned.... I don't think the seats have been cleaned in over a decade, if ever.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,571
    1,636
    NJ-USA
    Have you checked the air pressure in the spare?
    I suggest getting a scanner (like the Autel) sooner rather than later. You do not want to be in the middle of a "vehicle breakdown" event and then have to order, set up, and navigate a new tool.
  6. Leadfoot J. McCoalroller
    7,252
    6,785
    Pennsylvania
    2018 Prius c
    So why not do the first few cleanings on somebody else's equipment, like the big vacs at a car wash?
    Then follow up with smaller home gear to maintain it later.
  7. rjparker
    8,162
    4,841
    The first thing you need for self maintenance is a reasonably good understanding of how a Toyota hybrid works. Not every mechanic knows this and many don’t work on them as a result.
    After developing a basic knowledge base of a very complicated design, then you should understand the routine maintenance requirements like checking & changing fluids, replacing air and cabin filters, when to change spark plugs, rotating tires and inspecting brakes.
    There are many computers in a Prius and a good code and live data reader is needed to even ask questions here most of the time. You will hear about the hacked Toyota scanner Techstream and various others including kind of free apps (Dr Prius battery data) and better paid apps like Autel’s described above.
    Along the way, understand the common problems like hybrid battery failures, brake by wire issues and oil burning concerns.
    One thing for sure ; an 18 year old hybrid will need repairs and some repairs can cost $2000 US or more. The best strategy is to learn what you can and do oil and filter changes yourself as an easy way to save money. Having a good independent hybrid shop lined up will save you thousands when the big repairs are needed.
  8. Prius2006GuitarGuy
    Sweden
    Nope.
    Do you suggest any particular tire pressure checker? Digital or mechanical?
    Good point, I'll order the Autel today.(y)
    That's an idea, thanks!
    Thanks for the advice, I shal order the Autel today and try to gain knowledge in the highlighted points above.(y)
  9. Prius2006GuitarGuy
    Sweden
    Was just going to pick up the Autel ap200 when I stopped over at the Autel website and they say that model is discontinued - do you guys still recommend that model or should I pick something else up?
  10. dolj
    dolj Senior Member
    7,773
    3,937
    Wellington, New Zealand
    What does the Autel website state is the replacement for the AP200?
  11. T1 Terry
    T1 Terry Active Member
    614
    323
    On a slightly different direction, rotating the tyres was mentioned in a previous post. There are two different types of tyre construction, the early type were known as "rag" tyres and the cases tended to get out of shape, so there was a system of swapping the tyres diagonally, left front to right rear etc ...... but this only applies to the old type of tyres.
    The more modern construction design used wire rather than polyester belting when constructing the tyre. Steel belted tyre develop a rotational direction that shifts the steel belts to perform best when turning in that direction ....... if you swap them over from one side of the vehicle to the other, the steel belts will try to shift the other way to suit that direction of rotation ..... often resulting in a tyre case failure.
    With steel belted radial, mark on the out side of the tyre, which direction it was rotating before you remove it from the vehicle. The tyre can move from front to back on the same side and it will continue to rotate in the same direction and not cause any potential case failures, but the tread on the tyres will last a lot longer.
    Front tyres do the majority of the braking grip and cornering, this causes the tread to wear in different places to the wear patterns on the rear types. Swapping them from front to back will allow the tread to flatten out any ripples that may be developing, failure to do this will result in those ripples developing into serious uneven tyre wear.
    Brake fluid changing: not something for the beginner, but not something that should be ignored. Brake fluid absorbs water every time it heats and cools, build up enough water and not only will it eat away any metal surfaces in the braking system, if the water builds up to a sufficient %, it will boil off as steam ...... that old story you hear about an uncles mates sisters brother was driving down the hill and the brake pedal suddenly went to the floor, no brakes, then later is came back was sort of soft and spongy ...... that was the water boiling in the brake fluid because it was well past its use by date. Never leave the cap off a bottle of brake fluid, it will absorb water and be useless, even if it looks like new.
    When you are ready to change the engine oil and filter, add a bottle of oil system cleaner/flush and run the motor till it is warm to hot, then drop the oil and filter while it is still hot. This will remove some of the rubbish that has built up in the engine internals. If you do it each oil change, and change the oil filter each service, you will notice the oil stays the new colour for longer rather than going black straight away. The going black is the oil trying to clean up the inside of the engine, so once it is clean, the oil can do its proper job of lubricating all those moving parts
    End of todays tutorial :lol:
    T1 Terry
