Strange engine braking behavior, Prius 2009
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Louis Horvath, Sep 6, 2024 at 8:58 PM.
  1. Louis Horvath
    Louis Horvath Junior Member
    42
    Prevost, Quebec, Canada
    I'll make this simple.
    Had a 2005 Prius I loved. Sadly after 260k miles the engine just shakes and shakes even if I changed the spark plugs and coils. Car is worth less than a tow to my mechanic :(
    SO I BOUGHT A USED PRIUS 2009.
    Works great but I'm having a strange issue.
    I use engine braking a lot. Never had any issue with my Prius 2005.
    On the 2009, when I use the engine break it suddenly cuts loose at about 6-12 miles per hour, even on flat terrain.
    That is I have to press on the break or else it's as if the engine break has "let go".
    Same feeling when the car uses the ABS but there's no ABS light. To be clear, I'm not using the break pedal UNTIL the engine break lets go.
    There's no codes, no lights on the dashboard.
    Is this expected behavior for a 2009?
    Full disclosure, I brought the car to my local mechanic (that I trust completely) because there was an ABS issue - apparently the wheel shaft has coding gears to count the rotations and one of the "teeth" was in a bad way. He changed the whole shaft.
    This issue does not bother me too much but I'd rather not give up the use of the engine break.
    Any debugging suggestions welcome :)
  2. Tombukt2
    9,788
    1,709
    When my '09 was doing almost exactly this my hybrid battery was actually going south at the time I didn't know it but quickly got up to speed. And that's the only thing I can think of that would have been making that happen and there were other things going on too but that's not for this discussion. As soon as the hybrid battery was replaced a whole bunch of problems went away but I do remember this region breaking business kind of just not working at a pretty slow speed 10 miles an hour or something along those lines and like it just clicked off I don't think it does that now I'll check it in the morning I rarely use my friction brakes until I'm at the stop sign and I have to clamp on the rotors to not roll forward or backwards that's about the only time I'm clamping with the hydraulics where I'm driving I have nothing but time.
    Louis Horvath likes this.
  3. bisco
    49,760
    idk much about engine braking, but isn't 6-12mph the area where regen cuts out and full friction braking takes place?
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,343
    6,023
    Columbia, SC
    I have to ask....why do you use the B function so much?
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,571
    1,637
    NJ-USA
    "This issue does not bother me too much but I'd rather not give up the use of the engine break."
    Times two.
    Slowing a car down requires doing "something" with the kinetic energy (mass x velocity). Normal hydraulic brakes mechanically turn it into heat via friction. Engine braking does "the same thing" in a different manner.
    Regenerative braking converts kinetic to electrical energy (with some heat due to efficiency losses), but you get to reuse that instead of it all being "wasted".
    Normally, a Prius has a low level regen braking going on when you coast. This mimics the feel of a "normal" car with slight engine braking effect when the throttle is closed.
    Stepping on the brake pedal tells the ecu how fast you want to slow the car. The ecu decides how much regen vs friction braking to use. (hint - it's a bunch more regen than "coasting").
    Now on a long braking event - say going down a mountain - regen will "fill" the hybrid battery to its limit. That leaves only the friction brakes, which can overheat with constant application (the Prius is kinda heavy for its size).
    So Toyota added B mode, which shifts more of the rotational kinetic energy from the wheels into forcing the engine to spin (engine braking). So less regen, and less friction (at the wheels). It's slowing the car down, but it's wasting energy.
    So, using B mode all the time to slow down is going to reduce MPG vs normal (light pedal apply) braking that uses lots of regen.
    As for "is this normal"? No idea since I never have any reason to use B mode.
    Brian1954 likes this.
  6. pasadena_commut
    pasadena_commut Senior Member
    1,581
    475
    Southern California
    The main time I use B mode is when descending from mountain passes when there is very long downward grade. For instance, the Grapevine after Lebec on I5 northbound out of LA. That is a 2600 ft. descent in 10 miles (roughly, which takes about 14 minutes). For this descent the headlights are on, the cabin fan is blowing at max, and the radio and defrosters are on. All of those are to provide a destination for the power coming out of the regen braking other than the HV battery, which unfortunately tends to be nearly full just as I pass Lebec, and so hasn't got much space left to hold more energy.
    Sometimes I also use B mode when descending a shorter but very steep grade, in that case usually without all the other electrical loads added.
    I don't recall if I ever worked out the energy/power for the grapevine descent. Let's see, E = mgh, mass of a Prius with one passenger is ~3000 lb so about 1360 kg, g is 9.8 m/s, 2600 ft is around 800m, which gives E = 1360 * 9.8 * 800 = 10662400 Joules = 10.7 MJ. (A stick of dynamite is around 1MJ, but of course that is all released in a fraction of a second, not 14 minutes.) Mean power would be 10662400/(60*14) = 12.7 kW. Some, maybe half(?), will be lost to air and rolling resistance, and the remainder is roughly the same as the power from 6 100 W bulbs.
  7. Louis Horvath
    42
    That's a fair question.
    Essentially, while I'm about to stop, I use engine breaking to get the engine to stop earlier in order to save on gas.
    If I stay in drive (and am about to stop) I found the engine stays on longer and only stops when the car is 100% immobile.
    I might be hallucinating but I found I saved on breaks and fuel that way.
    I'm going to do a few days without the engine breaking and see if the problem still occurs.
    I'm actually thinking of getting a Toyota car dealer to look the car up - it was part of the plan when I got the car but life just happens.
  8. Louis Horvath
    42
    That's an interesting observation. My 2005 is still in the driveway so swapping the hybrid battery is in the cards (I've done this twice before and it's the reason why I wanted to get a Prius - giving me some options).
    Thanks for the suggestion!
  9. rjparker
    8,162
    4,841
    First it’s braking not breaking. As others mentioned, use of B mode decreases mpg. The reality is normal pedal braking uses regen just as much and actually saves the friction brakes and rotors. My 2012 has 315,000 with original rotors and front pads. I replaced the rear pads simply because they were off for a rear wheel bearing.
    Regen normally continues below 6 mph but friction brakes are then used as well. Only if you hard brake at higher speeds will the hydraulic brakes be applied. Some can wear out their hydraulic brakes and reduce mpg simply by their driving style.
    By the way, if your Master Cylinder/ABS is faulty regen goes away in many cases.
  10. dolj
    dolj Senior Member
    7,775
    3,937
    Wellington, New Zealand
    Once warmed up, the engine will always stop immediately when you lift off the accelerator. The only exception to this is when the engine needs to move from stage 3 to stage 4 of its warm-up cycle. At this point, the car needs to be doing less than 4 km/h (2.5 mph) for 5–7 seconds for the transition to take place. Once you're in stage 4, the engine stops running more often in general driving and always when you're decelerating or stopped.
    Yeah, I'm going with you're hallucinating.
