TSB EG-0127T-1014 (SW update to avoid cylinderhead gasket failure)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OptimusPriustus, Sep 19, 2023.
  1. rjparker
    10,103
    6,267
    There are many temperatures in a Prius including two engine coolant sensors. These are the temps I monitor through obd2, in this case Car Scanner. There are others in the hvac and battery systems as well.
  2. Air_Boss
    Air_Boss Senior Member
    4,190
    1,177
    New Yawk
    2012 Prius v Five. On the P12 device, oil temperature is an available to be displayed, OBD2 value, along with other internal and ambient temperatures. I don’t the location of know its sensor origin.
  3. ChapmanF
    18,101
    Can you screenshot that? rjparker's screenshot shows some PID information, such as to distinguish "coolant 7C0" from "coolant 7C4".
    What I'm wondering isn't limited to the location of the sensor, but extends to whether there is such a sensor, or what the P12 device is showing you as "oil temperature" instead.
    Brian1954 likes this.
  4. Air_Boss
    4,190
    1,177
    New Yawk
    Best to inquire with the P12 folks. Brush up on your Mandarin…
  5. ChapmanF
    18,101
    Anybody seen any other OBD device that purports to show an "oil temperature" from a 2012 Prius v Five?
    Anybody seen such a value in Techstream?
  6. rjparker
    10,103
    6,267
    I suspect the Chinese translation of “Transaxle fluid temp” may be “Oil temp”.
  7. douglasjre
    douglasjre Senior Member
    2,172
    716
    Null, NL
    Where is the oil temp shown? Where is the sensor on the engine?
  8. douglasjre
    2,172
    716
    Null, NL
    Nope. I haven't plugged in aftermarket one stuff since I saw a pro go haywire from a Chinese Bluetooth dongle made the car go bizerk. And techstream doesn't list an oil temp.
  9. douglasjre
    2,172
    716
    Null, NL
    A transaxle is a manual transmission.
  10. ChapmanF
    18,101
    A transaxle is any unit that combines a transmission (variable ratio power delivery from the engine) plus a final drive axle/differential. Transaxles are what front-engine, front-wheel-drive cars generally have. There can be manual ones, automatic ones, and CVT ones like the Prius has.
    Air_Boss likes this.
  11. AzusaPrius
    AzusaPrius Senior Member
    2,179
    919
    For chapman
    Attached images for eCVT & CVT
    Just in case you want to nitpick. Screenshot_2024-09-09-08-39-40-1.jpeg Screenshot_2024-09-09-08-45-29-1.jpeg
  12. Air_Boss
    4,190
    1,177
    New Yawk
    OK, I'll bite. How does the eCVT transfer ICE and EMG power to and from the front axles?
  13. AzusaPrius
    2,179
    919
  14. Air_Boss
    4,190
    1,177
    New Yawk
    IOW, a transaxle.
  15. AzusaPrius
    2,179
    919
    No...dont go around in a circle.
    They are different and it is not labeled a transaxle
    #115 AzusaPrius, Sep 9, 2024
  16. AzusaPrius
    2,179
    919
    They call it a P410 I think but it acts as a transaxle
  17. ChapmanF
    18,101
    I can hardly wait for Azusa to identify where he got the above screenshots, and why any of us ought to consider that source any more reliable than other more traditional ones, such as the Toyota repair manual for the car, for example.
      File size:
      15.3 KB
  18. rjparker
    10,103
    6,267
    Toyota calls it a transaxle - end of story for most of us. It is amusing that this is the issue in a thread about head gaskets that morphed here after I quoted “Transaxle fluid temp” from a Toyota document describing temperature limits.
    The professor who teaches hybrid and electric cars:
    #118 rjparker, Sep 9, 2024
  19. ChapmanF
    18,101
    P410 it is!
  20. OptimusPriustus
    OptimusPriustus Active Member
    332
    141
    Finland
    I thought electric waterpump in combustion engine is very rare but it appears it’s not. Some BMW, Audi have it also and Corvette C7. Prius was early adopter though. And that it’s re-programmable is so cool. Fascinating car for it’s age
