Audio, ACC and the door
Discussion in 'Gen 5 Prius Main Forum' started by Seb, Sep 5, 2024 at 7:45 PM.
  1. Seb
    Seb New Member
    Thursday
    New york
    2023 Prius
    I put my 2023 prius into ACC mode to listen to audio and find the radio no longer turns off when the car is turned off. It shuts off only when the car door opens. How do I reverse this so the audio turns off when the car turns off? I can't find anything in either the regular or multimedia manuals
  2. PriusCamper
    PriusCamper Senior Member
    11,216
    4,576
    Pacific Northwest, USA
    Make sure you've gone through all the functions on the dash thoroughly to be certain you haven't overlooked anything. Then next step is getting the software they replaced Toyota Techstream with and the correct dongle to connect your laptop to the car and you'll have access to almost all the same settings that Toyota mechanics have.
    If it were a younger generation Prius I'd tell you to simply buy a mini-VCI dongle online for $35 and it comes with a hacked copy of Toyota Techstream. But I read recently that Toyota has a new system for newer vehicles. Maybe someone who knows more can add to this thread?
  3. KMO
    KMO Senior Member
    1,594
    446
    Finland
    2023 Prius Prime
    Sounds like the "ACC customise" option. Flip that to the other setting. One of the settings makes the power states more automatic and gets rid of the ACC/POWER ON distinction.
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    907
    506
    Cow-lee-fornia
    2023 Prius
    You don't want to sit there in just ACC/ON mode. You will drain the 12v battery. Just put it in READY and avoid all the headaches of a dead battery.
  5. Seb
    Seb New Member
    Thursday
    New york
    2023 Prius
    Would you please clarify whether "flip that to the other setting" would be done if and only if I use Toyota's software as suggested in the other response?
    I have not gone that route, and have so far been unable to locate any way to customize the ACC setting on either the multidisplay screen, or through the Settings feature(s). Should mention that my Gen 5 is a hybrid, not Prime
    Many tx
  6. CooCooCaChoo
    907
    506
    Cow-lee-fornia
    2023 Prius
    The Prime is a hybrid. The only difference is its got a bigger battery.
  7. KMO
    KMO Senior Member
    1,594
    446
    Finland
    2023 Prius Prime
    No, it's a setting in the multimedia screen options: Settings / Vehicle customization / Utility / ACC customize
  8. AndersOne
    AndersOne Active Member
    311
    179
    Europe
    2023 Prius Prime
    ACC is needed for automatic car washs though
  9. KMO
    KMO Senior Member
    1,594
    446
    Finland
    2023 Prius Prime
    If you're talking about leaving the car in "N", you can do now that in OFF state with some magic gear lever juggling before turning off. (See manual section "Keeping the shift position in N without activating the automatic P position selection function".)
    Otherwise, I think you've always needed to be in at least POWER ON to select N, not ACC.
    The ACC customise option removes the separate ACC mode, so you only have OFF, POWER ON and READY.
    And it makes it so that the radio/navigation system stays on when you go to OFF, until you open the door - most usefully giving you a next charge time indication with "charge now" button - and I think it also makes it start to initialise when you approach/unlock so it starts up faster.
    I don't think that impacts N selection.
  10. AndersOne
    311
    179
    Europe
    2023 Prius Prime
    Yeah ACC + N was recommended by the manual for an automatic car wash eg like a drive through car wash - but realistically I need to switch directly drom READY+D to N as I enter the drive through. I would not mind stainy in READY+N but I assume the car willl go wild with emergency braking and such, which is not what you want to happen when pulled through the car wash.
    I whish there would be a simple car wash mode like with Teslas...
