i ran out of gas can’t restart
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gino Veltri, Sep 9, 2024.
  1. Gino Veltri
    Gino Veltri Member
    413
    40
    so i ran out of gas and as soon as i noticed i pulled over n stopped battery at 25%. went and got a liter of gas n put it in and the car would start n try to charge the battery but then stop. tried that a few times before calling it a night. … now i switch hybrid batteries and put in more gas but it only clicks once on startup ( instead of the audible 3 clicks of relays when you hit the power button). What could i be missing here?
  2. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    Wonder if one liter is enough. You mean one gallon? Also can you hear the fuel pump priming?
  3. Gino Veltri
    Gino Veltri Member
    413
    40
    i put more gallons in because i figured maybe a liter wasn’t enough. i heard it priming i think last night, now i can’t even get the car on. the hybrid makes one click and never readys
  4. Gino Veltri
    Gino Veltri Member
    413
    40
    i actually have no idea what ariel pump priming sounds like
  5. saneesh8
    saneesh8 Member
    208
    52
    Allen, TX
    Do you have a scanner?
    Brian1954 likes this.
  6. fuzzy1
    10,583
    One liter is nowhere near enough. Put in enough so that the low fuel warning quits blinking, before even thinking of trying to restart it.
    Once you tried several restarts without adding in that much fuel, it may have locked out further attempts in order to protect the hybrid battery. Try disconnecting the 12V battery long enough to erase volatile computer memories, so that it 'forgets' that it is intentionally locking you out. Then re-connect the 12V and try again.
    From your Owner's Manual:
    #6 fuzzy1, Sep 9, 2024
  7. Brian1954
    Brian1954 Senior Member
    2,368
    953
    South Central PA, USA
    My guess is that the hybrid battery safety plug was not installed correctly. You need to do all three steps for correct installation.
  8. Gino Veltri
    Gino Veltri Member
    413
    40
    that’s what i’m thinking what Are the three steps it goes in push down then clicks but i’m just getting one relay click on start up
  9. Brian1954
    2,368
    953
    You insert the safety interlock, then you flip the handle down, then you slide the handle hard. I will try to find the diagram.
    #9 Brian1954, Sep 9, 2024
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Good luck! Keep your fingers crossed.
  11. mr_guy_mann
    mr_guy_mann Senior Member
    4,076
    1,992
    NJ-USA
    Have you ever gotten a capable scantool? Sometimes it can be much easier to figure things out if you ask the car what it doesn't like.
    drone13 and Brian1954 like this.
