P3191 and P0A0F/204
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by black_jmyntrn, Aug 10, 2024.
  1. mr_guy_mann
    mr_guy_mann Senior Member
    3,577
    1,641
    NJ-USA
    If whatever you have in the fuel system leaves a residue as it "dries", then your fuel injectors are garbage.
    Without a pressure gauge, you can't know if the pump and regulator in the tank work properly.
    And you have to get all the "bad stuff" flushed out before replacing the injectors - otherwise they could get gunked up as well.
