Passenger front rotor/wheel hot. Stuck caliper?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Thepriusthatcould, Sep 9, 2024 at 12:15 AM.
  1. Thepriusthatcould
    Thepriusthatcould Junior Member
    Andover, MA
    2004 Toyota Prius. I noticed after a 5 mile drive the front passenger tire and rotor was hot. Almost enough to burn. I could feel the heat radiating from the tire. Driver's side tire felt cool to the touch.
    Recently, after not driving for the car for a week and after rain, the car seemed "stuck" and required a little gas to get moving while on flat ground.
    The car can't really move while in drive with no gas applied on flat ground. I think it's because of the right front tire.
    No noises, did front wheel bearings a year ago. Front pads and rotors 3 years ago. Calipers are at least 7 years old but probably original.
    Jacked the car up on the front. Could rotate the driver's side tire but not the passenger while in neutral.
    Should I just replace the calipers? I am getting a tool to compress the pistons and will check to see if the slide pins can move. I am thinking I should test to see if the caliper pistons can be pushed inward.
    Thank you
  2. Tombukt2
    9,802
    1,711
    You just use a pair of channel locks to squeeze the caliper down If you can't squeeze the caliper down with slip joint pliers simply call channel locks in America you have a problem I can almost squeeze the pistons down in my front calipers with my bare thumbs . No kidding. And slide pins or the caliper bar should pull across with your pinky or middle finger without applying your whole body weight behind it to move the slide pins back and forth If not pop that mess off clean them with carb spray and a little bit of crocus cloth commonly called sandpaper for metal spray it off again wipe it regrease it with the proper brake grease You can get into a whole another hullabaloo about that too but it really doesn't matter You don't grease the brake pads in the rotors. Brakes of this type are similar on Corolla Camry matrix etc not a real big difference in calipers and pistons and rotors very similar All that stuff should be very inexpensive to deal with and it sounds like most of it will be just greasing slides or replacing pins and in this day and age you would just replace the caliper it's probably cheaper If you're way out in the country or in the Australian bush you can pop the caliper out clean the mess up again with your metal sandpaper buy some new rubbers It's like a piston ring made out of rubber for the piston in the brakes lube that up with brake fluid and push it all back together Not really much to it but these days are remand caliper locally is only about 20 bucks That's without the bracket and all. But yes all of that should pretty much move by hand You should need any hydraulics and what have you to make this stuff move when you push your piston in after you sand the boar clean up the piston and add a new rubber and some brake fluid as lubricant you should be able to push that right back into its hole with your fingers. Then you should be able to rotate your wheel around and around and backwards and all that with just one hand on the tire wax on wax off.
  3. ChapmanF
    15,964
    Sounds like you sure enough have a stuck caliper.
    You can buy a caliper rebuild kit from the dealer (includes all the rubber and miscellaneous bits for both calipers, plus a little packet of the correct grease).
    If you're sure the caliper you've got is original, you'll probably end up with a better caliper if you rebuild that one than if you throw on a cheap reman. (Then you'll get your core charge back when you turn in your original caliper, which will end up getting excessively sandblasted, rebuilt with cheesy parts, and appearing on a store shelf somewhere as a cheap reman.)
    More on that subject here. Includes how to check that the caliper piston properly returns when you're not braking. This is worth checking on a store-bought reman caliper before even installing it ... one I bought did not, right out of the box.
    Also describes how to search for a caliper from Toyota's reman parts program. Those are good, but they're not always available.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,580
    1,641
    NJ-USA
    There are 4 reasons why a single (disc) brake is dragging.
    1) the brake pads are seized in the caliper bracket.
    2) the piston is seized in the caliper.
    3) the slide pins are seized in the caliper bracket.
    4) the caliper can't release because brake fluid is trapped (usually a faulty brake hose).
    I begin by lifting and supporting the car. Then remove the wheel, and open the bleeder screw to see if relieving any pressure releases the brake. If so then replace both front brake hoses.
    If not then disassemble things until you find the problem.
    Seized pads are the "easiest" fix. Seized pins sometimes require replacement brackets.
    A seized piston usually means the caliper should be replaced. It can take lots to extract the piston (which will be damaged), then the bore is also likely damaged (corroded).
    I might put a kit in a ($$) caliper that has a bad dust boot - IF the piston looks good. Anything else gets replaced.
    Now I absolutely loath cheap reman calipers (say it with me kiddies... "A1 - Cardone" The devil himself). I've spent way too much of my life dicking around with bad parts. The only caliper I'd get for my cars now is Toyota from the dealer.
    When it's all apart, look at the pads and rotors. Maybe they're ok, maybe they overheated (and the pads are "cooked" or the rotor warped).
  5. Thepriusthatcould
    Andover, MA
    Thank you for the reply.
    On step 1, I release the brake bleeding valve with the wheel off to see if brake releases. Do I test this by pushing the caliper in or if the wheel spins? With the caliper still on the rotor?
    I am prepared to replace front calipers, pads, rotors, and hoses if necessary but it would be great if I could save money.
    I agree on the remanufactured parts. You save a few bucks but I wouldn't want to use it for anything safety related
  6. Thepriusthatcould
    Andover, MA
    Thank you for the reply. I see Rock Auto offers new calipers for $70-$80 dollars a piece but I don't know if they are actually new or remanufactured. Remanufactured one's can be had for $30 but I don't think the risk is worth it.
    Thank you for the link!
    Rock Auto caliper choices:
    2006 TOYOTA PRIUS 1.5L L4 ELECTRIC/GAS Caliper | Shop Now at RockAuto
  7. Tombukt2
    9,802
    1,711
    You just cracked the bleeder Don't do anything but crack the bleeder does fluid come out It won't squirt but do you see pressure relief fluid rising up out of that zerk fitting you just opened now close it Don't want to let any air in basically close it and see if you're now can jog your rotor and wheel studs back and forth You're probably in park so they're not going to move round and round but you can now turn the rotor back and forth a few degrees You can see it sliding through the pads where it wasn't a minute ago sometimes I use my pry bar in between the wheel studs if my hands not feeling up to the task now it's either moving or it's still stuck like it was before You tell me. If it just got loose look at your hoses they're rubber they look deteriorated crushed otherwise fubar replace them I've replaced the brake hose about four times in my 45 years working on cars believe it or not and that was in the '80s and '90s and usually the hose would have a bubble blister etc in the rubber outer portion of the hose at least You could see it didn't look like it should be there I'm not sure what the problem is with remanufacturing calipers I really don't Toyota units are very basic there's not a lot going on some of the newer ones even have composite Pistons which are real easy to work with unless they've overheated and melted or broken The repair kits from the dealer are relatively cheap or from any company that manufactures the rubbers you talking an outer boot and a rubber piston ring if you will wipe out and sand the bore with your flex hone of that size or just croaka's cloth on your finger not really going to be much science to this it'll turn silver and you'll wipe it out and so on fit the new rubber piston ring to the piston a little bit of brake fluid around the rubber you don't have to kill it You don't have to flood the bore to install the piston You want to put it up not dry but not soaking wet
  8. mr_guy_mann
    3,580
    1,641
    NJ-USA
    Open the bleeder and some fluid should dribble out. If the problem is hydraulic, then the rotor should now move more freely.
    If not, then the problem is mechanical and keep going.
