Oil drain plug gasket sealed to oil pan
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Matt Werser, Sep 10, 2024.
  1. Matt Werser
    Matt Werser New Member
    Does anyone have a picture of the oil pan drain hole without the gasket on a Prius v or third gen prius. I think a rubber gasket I got from the toyota dealership (not the blue one that's more commong) and put on last oil change is totally sealed to the oil pan and I've mangled it a bit trying to get it off. Just want confirmation I'm not mangling the oil pan, just the gasket. I've attached a picture for this too.
    Thanks!
  2. Mendel Leisk
    41,170
    I’ll jar them loose putting a slim, flat-bladed screw driver at the junction of washer and oil pan, give it a tap with a hammer.
    and yeah looks to be the washer; shouldn’t take more than a light tap.
  3. Matt Werser
    Thanks for the response. I've tried that, unfortunately since there is no metal component in the washer (fully rubber gasket?) it wont budge, just flake off as you see in the picture. I'm going to try heating the rubber with a heat gun and scraping it off!
  4. Matt Werser
    The heat gun did the trick. Thanks!
  5. ChapmanF
    17,953
    Happens to me pretty much every oil change. I generally just poke the tip of a small screwdriver right up through the hole at a shallow angle so it's between the oil pan threads and the gasket on the opposite side, then push gently by hand on the screwdriver handle to pop the gasket off. Gently is the watchword, no need to go ballistic and nick the threads.
    Air_Boss likes this.
