Headlights won't turn off
Discussion in 'Gen 2 Prius Main Forum' started by rogerchin, Sep 11, 2024.
  1. rogerchin
    rogerchin New Member
    17
    I bought my car about 2 months ago and never noticed the headlights not turning off until recently, previous owner didn't mention anything about it. And by turning off, I mean using the switch to turn it off. It will turn off when I shut off the car and open the door. Other than that, once I turn it on, release the emergency brake, they will come on and again, even if the knob is on "off", it's not off.
    What could be the issue?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    #2 TMR-JWAP, Sep 11, 2024
  3. ChapmanF
    18,478
    If they don't come on right away when you turn the car on, but do when you release the parking brake, that's a dead giveaway it's the Daytime Running Lights you're seeing. That's the exact time they turn on, and they use the same bulbs as the headlights, at a reduced brightness.
  4. rogerchin
    17
    That explains it but when I turn on the headlights, it's like 5% brighter, almost no difference.
