What 'brand' 12v battery do you recommend for a Prius?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Sep 13, 2024 at 8:28 AM.
  1. ski.dive
    ski.dive Active Member
    915
    235
    Hutchinson Island,FL. Mt. Snow,VT
    Is this WALMART BATTERY for the Prius any good?
    #1 ski.dive, Sep 13, 2024 at 8:28 AM
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,009
    666
    Monument, Colorado USA
    How much are they? I just spent $208 at my Toyota Dealer for my wife's 2017 Prius and it came with an 84-month warranty. (And I noticed the CCA went up from 295 to 470...I know we don't really use that to start but they must've beefed-up the batteries a bit.
  3. Danno5060
    Danno5060 Member
    215
    97
    Wyoming
    I put two of them in my Gen 2, neither of them lasted as long as the original.
    When the battery in my used Gen 4 started failing, I figured what the hell and called the local dealer's parts department. The Toyota battery cost less, had better specs, and a better warranty.
    Oh, and I don't know if the AGM is a good choice, but to be honest, the last one I put in my Gen 2 was a Die Hard AGM.
  4. Tombukt2
    9,843
    1,717
    I I would say read the reviews and see what other are experiencing for this group size they're pretty much Prius and Prius like vehicle so quite similar and all of that I'm usually a problems run they run pretty deep but just by looking at the battery and the basic specs on it it should be able to hold its own and usually Walmart will do you reasonably well although on some batteries I have noticed you have to be very careful with they're very stringent about honoring the warranty kind of interesting.
  5. bisco
    49,778
  6. pasadena_commut
    pasadena_commut Senior Member
    1,595
    477
    Southern California
    It is made by a reputable manufacturer, although I cannot recall now which one. Read all reviews at Walmart.com. I would get one. Apparently they also sell (or maybe sold) one with the lower nonSKS CCA rating, and people who ordered the bigger one online sometimes received the smaller one at delivery or pick up. The one shown in the picture is the bigger one. However, I would run it past my portable battery tester in the store first, because sometimes batteries are DOA, or near to it, and what's the point taking that home? (Not just at Walmart, any time I buy a car battery, for any car.)
  7. Aegean
    Aegean Active Member
    431
    188
    Alexandria VA
  8. ski.dive
    915
    235
    Aegean likes this.
  9. pasadena_commut
    1,595
    477
    Southern California
    That is the smaller 325 CCA version. Right there in the URL. Open the page, click on the little red down arrow next to "More" and it opens up to show it is 325 CCA. I didn't think Toyota even made those anymore. Anyway, the 410 CCA Walmart one is ~$180, and the price at Puente Hills Toyota (usually the cheapest near me) for the 325 CCA is $182. Same price, 3/4 of the capacity for the Toyota one.
    Wow, this battery with a similar part number doesn't give a CCA value at all, even when fully expanded:
    HV 12V Battery #00544-21171-LEX | Autoparts.toyota.com
  10. bisco
    49,778
  11. ski.dive
    915
    235
  12. Aegean
    431
    188
    Alexandria VA
    My 2006 Prius came with 325 CCA 18 years ago when I bought it. I replaced the 12v battery just once in all these 18 years with OEM 325 CCA again. Never had any issues.
  13. pasadena_commut
    1,595
    477
    Southern California
    The SKS models are supposed to use the larger capacity battery.
    I should add that the Ah and CCA ratings on S46B24R batteries for the Prius are inconsistent between different manufacturers. Here they are sorted by CCA then AH
    ?, 325 Super Start Platinum AGM (O'Reilly brand)
    ?, 325 TrueStart AGM (Toyota brand)
    45, 325 Yuasa HJ-S46B24R (Manufacturer)
    46, 325 Motomaster Eliminator (Canadian Tire brand)
    45, 370 Marathon AGM Auxiliary (BatteryMart)
    45, 370 Varta AGM
    36, 410 AC Delco
    41, 410 Interstate MTX-S46B24R AGM
    41, 410 Duralast AGM (Autozone brand)
    41, 410 DieHard AGM (Advance Auto and elsewhere)
    45, 410 Everstart Platinum AGM (Walmart brand)
    ? if I couldn't find the value with the other specifications. Bizarre that some don't give this value, as it is not difficult to measure.
    #13 pasadena_commut, Sep 14, 2024 at 7:46 PM
