Expansion valve - how to replace
Discussion in 'Gen 2 Prius Technical Discussion' started by Wecandothat4u, Sep 13, 2024.
  1. Wecandothat4u
    Wecandothat4u Junior Member
    Cambridge, MN
    I've searched both Prius chat and Youtube and found nothing on this. Apologies if it is in plain sight and I am not seeing it. And this might not even be the problem, but we have high pressure of 350 with less than one can of freon after replacing the condenser with a brand new one. We've actually just replaced the engine and some other stuff, but this is one of the last issues. We're thinking the expansion valve might be the culprit. Where is it and how much must be disassembled to replace it? We have a parts car where the AC was working fine, so parts are right there. Thanks in advance.
  2. Leadfoot J. McCoalroller
    8,094
    7,577
    Pennsylvania
    2018 Prius c
    Not common as a DIY repair so there may not be many DIY info sources.
    But there is the OG factory repair manual- probably well worth the rent for a job like that.
    Wecandothat4u likes this.
  3. ChapmanF
    18,250
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,976
    NJ-USA
    How long did you run your vacuum pump to evacuate the system before charging? What vacuum reading did you achieve? Do the radiator fans operate when the A/C turns on?
  5. Tombukt2
    13,045
    2,338
    Sounds to me like icing happening and clogging the system if it was ever able to run or you've got a kinked hose or something or some garbage literally in some passageway. Relegate this car to not summer duty they're so plentiful now You can get another one for near nothing with the air conditioner working at least in my area. You're taking the whole dash out of the car and taking the whole air conditioning evaporator heat box out of the car and their resides your expansion valve just like all the other older Toyotas with expansion valves they're in the evap box My experience is they rarely go bad unless they get trashed up from an explosion I had a 74 Corolla with a hang on air conditioning unit in 78 and 93 it was still running fine The air conditioning the car wasn't in such good shape but the air would blow snowflakes out the vent underneath the glove box It was a Denso hang on units with a Tecumseh type upright pump the old piston type. In any of my older Corollas all the way up through 97 never replaced the expansion valve in any of them and had very cold air and all of my cars because we live in the southeast USA and no air is not an option generally speaking. I've replaced some damaged evaporators leaking etc and much older cars than the Prius mostly Toyotas but not expansion valves matter of fact that unscrew the old expansion valve and screw it right to the new or add the evaporator right to the existing expansion valve no problem and they're not very expensive the expansion valves that is. That's just personal experience 47 years driving predominantly Toyota vehicles since the KE series Corolla.
  6. Wecandothat4u
    Cambridge, MN
    Thanks. Good advice.
  7. Wecandothat4u
    Cambridge, MN
    That gave me a lot of good info. Thanks.
  8. Wecandothat4u
    Cambridge, MN
    Ran the vacuum for over an hour. Reached -30 and held it for ten minutes before I charged it with a half a can of freon. The high side went to 350. I got nervous and shut it down. After a day sitting on the gauges the pressure has dropped, so I also suspect a leak. Not sure about the fans.
  9. Wecandothat4u
    Cambridge, MN
    I'm "building this one for my primary USPS package delivery vehicle. Just bought it, changed the engine and trans, gave it a new condenser, did some exhaust work. I want to make it right, so even though I do use the Trailblazer in the winter when it's bad, last winter was so mild, I drove a Prius all but two days. But normally, this is my summer car, so I need the AC to work. I have a parts car that the AC worked fine in and we already robbed the radiator and fans unit. I'm not opposed to changing whatever is necessary. My son is the labor and we've already swapped out the dash, since the old one was maxed out at 299,999.
  10. Wecandothat4u
    Cambridge, MN
    Thanks to everyone answering. I'm slow to answer right now due to some family medical issues, but I will read all answers and appreciate all the help.
  11. Tombukt2
    13,045
    2,338
    Well if you've replaced all those parts from one car to the other then you won't have any problems or qualms about pulling the dash again to replace the AC evaporator r and all that in the box that you want to replace I would certainly want to pressure test that evaporator. Before I did all that work putting in a new expansion valve and so on and so forth maybe check the heater core too while all of that is apart so that you will in fact make sure you go 500,000 mi pretty easily which the car will do with no problem with or without the air conditioning issue I've got four of them here and none of them have had the air conditioning issue as of yet and we're at 300,000 miles in most everything One is $190. And I'm in the southeast USA where air conditioning is not going to be not working. Another reason I guess why I have a few of the cars because I've heard the horror stories of the air conditioning so I've got three I can go through plus one more I have not been able to kill the air yet and I've done all the wrong things that everybody says you can't do more or less but I've done that to all of my Toyotas over 46 years and have never had any problems. When I was young and really ignorant and having a really good time I drove a Toyota 2tc 1600 hemi engine TE57 drove it 200,000 mi and never changed the oil never added yes changed no and it was running when I gave it to a friend of mine yeah I know.
