2008 Prius HELP lol
Discussion in 'Gen 2 Prius Technical Discussion' started by Heretolearn, Sep 14, 2024 at 1:05 PM.
  1. Heretolearn
    Heretolearn New Member
    WA.
    I got a 2008 Prius from a state auction with plans to keep a drive. At sixty thousand miles i got a new traction battery from Toyota also a new 12 volt. The car sat for over a year to the best of my knowledge.
    The car starts and shows charging. I clear code p3000 and P0AFA and they come right back.
    If the car Safe to drive?? Dr.Prius show block four Red And all RI Good Yet it is a brand new battery from Toyota. Should i drive it or is there something wrong. I read on permanent codes?
    Thank for your help.
    49,789
    you might need tech stream for proper codes and sun codes (INF codes)
    did it sit for a year after the hybrid battery was replaced?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,361
    6,032
    Columbia, SC
    Did you have the Toyota dealer install the battery? Did you purchase and install it? Did you purchase it and have someone else install it? Did someone else tell you they purchased it and then installed it? Was the HV battery ecu inspected to verify the socket wasn't corroded?
    Is the underlined "I" supposed to "it", as in the car had a new HV battery and 12v battery installed at 60k miles, prior to being auctioned?
    If so, what is the current miles? The way the sentence is currently worded, it sounds like you bought it and then YOU had a new HV and 12v battery installed.
    If the new stuff was installed prior to the auction, and the car sat for a year or more prior to the auction, then it's likely the battery has gone through some self-discharge, but may be recoverable if charged up. Relatively new OEM batteries are pretty tough.
  4. Heretolearn
    WA.
    Thanks
    My Steps so far, towed the car home. Used DRprius and car scanner and ran codes. I purchased a grid charger and got the battery up to 230 volts. The car started and ran. Drprius showed blocks 4,5 as being bad. The IR on other blocks varied. I purchased four used cells on ebay pulled the battery replaced the cells installed new bus bars, cleaned and checked all the plugs for corrosion. Still Red triangle. After reading trouble with rebuilt battery's, I purchased a brand-new OEM traction battery from the Toyota dealer. I already had purchased a brand new 12 volt from napa. I then installed the new traction battery that came with all new wires from the battery to the ecu area.
    Still have the red triangle come back after clearing codes. Code showed low voltage, Car starts and is charging when brake and pedal is pressed. I just purchased Ebay Tech stream after seeing 1700. from Toyota. Does the car just need to be drove? wait tell the warning light is fixed? There must be something i missing or need to look for. Thanks for the help.
  5. bisco
    49,789
    if you are trying to message me, it is not coming through, only my comments.
    you can just reply here, so everyone can help
  6. MAX2
    MAX2 Member
    299
    66
    Third Rock from the Sun
    You may have good HV battery modules, but the modules may be unbalanced. When the difference between them is the threshold voltage, the HV battery ECU indicates an error.
