Paint question
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Sep 16, 2024 at 6:15 PM.
  1. nudriver
    nudriver Member
    225
    26
    los angeles
    The roof and areas around the doors of my 2012 Prius started mysteriously peeling recently, and all at once. It's like if you have a sunburn, what happens when your skin sort of bubbles and then peels. We've had real hot temps in southern California this summer and my car is kept outside. Is this normal to see? When I drive around I rarely see cars with peeling paint.
    Took it to my body shop guy. He sprayed clear coat. A full paint job would be too expensive. Interested to hear the experience of others.
  2. rjparker
    8,188
    4,855
    Usually the plastic spoiler loses its clear coat first.
    Did your body shop sand off the peeling paint first?
    Was it just your clear coat peeling?
  3. nudriver
    nudriver Member
    225
    26
    los angeles
    Yes to both. How would I know if it was more than clear coat peeling?
  4. rjparker
    8,188
    4,855
    The color would be gone
    nudriver likes this.
  5. Mendel Leisk
    38,951
    Is it Blizzard Pearl? There was problems with that, took a long time for Toyota to acknowledge and act, but there is recourse now.
  6. nudriver
    nudriver Member
    225
    26
    los angeles
    Huh?! Seaglass pearl. Can I be compensated?
  7. Mendel Leisk
    38,951
    It’s just for blizzard pearl, the metallic white. AFAIK.
  8. DirkAshburn
    DirkAshburn Junior Member
    68
    24
    Virginia
    My clear on the front bubbled/peeled up. I sanded it down and sprayed it with 2k clear. I should have done a better sanding job, but it looks fine.
