Is the "Total Average" MPG legit?
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Will B, Sep 16, 2024.
  1. Will B
    Will B Active Member
    440
    397
    Denver
    2023 Prius Prime
    XSE Premium
    I've had my PPPXP (Pretty Prius Prime, XSE Premium) for a bit over a year now, upgrading from a 2003 Gen1. I like tracking data and for the Gen1 it was pretty easy. For the Prime tracking EV range is easy, but tracking HV efficiency has been messy. The tank readings I had found included EV miles, so were wildly inaccurate for MPGs. I've resorted to logging the DTE after filling the gas tank as an indicator of how I'm doing. Not great, but at least something.
    While fiddling around this past week I came across the "Total Average" MPG display while in HV mode. I had never seen it before. I guess the previous times I had scrolled by it I was always in EV mode, so it was showing EV efficiency.
    Is that what I hope it is, the cars best estimate of MPGs I'm getting in HV mode? If so, that would be cool, have folk been able to verify its accuracy? My car is showing 66MPG which is way too low to be a combination of EV+HV but seems a bit high to be HV only. The owners manual doesn't go into any detail unfortunately, just calling it "average fuel economy".
    If it is what I hope it is, I can finally start tracking MPGs by tank by using the Total (vs Trip) average and then reset on every refueling.
    BTW, don't laugh too much at the label under the display, I have trouble telling left from right! :)
  2. BiomedO1
    3,141
    1,664
    SacTown, Ca
    That's probably closest to being correct as far as OVERALL mpg, EV + HV. Looks like your doing a lot of ICE driving. Mine is around 115, because my commute is a few miles beyond my EV range. My ICE usually fires, warms up, then shuts down at the light, as I enter the parking lot to my facility. If it's still running when I park, I'll let the engine complete it's warming cycle before shutting down. You'll know when the warm-up cycle is complete because the car is stationary and in park. The ECU won't shut-down the ICE until the warming cycle is complete. Once the ICE stops, it's OK to shut-down the car.
    I don't think the car's ECU segregates EV vs ICE operations in their calculations, otherwise Toyota would be able to tell you when you need an oil change (like the GM products) rather than trip a alert every 5K. I know the gen4 can't do that and I doubt they've improved that on the gen5.
    The only way I can track actual ICE is by the miles on a tankful of gas driven, divided by the miles driven. Then use EV/ICE percentage to calculate how much is EV vs ICE. That's about as close as you can get.
    Hope this helps...
    #2 BiomedO1, Sep 16, 2024
  3. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    The Total Average MPG is a totally worthless value to me. Toyota doesn’t break out Miles on gas from miles on battery, so I keep track myself. It is a pain, but I want to know how many miles I get on a gallon of gas (46 MPG) and how many miles per kWh bought from the wall (3.35 mi/kWh or an average 42 miles for a 12.7kWh charge at 120volts)
  4. MAX2
    MAX2 Senior Member
    1,436
    486
    101
    Third planet from the Sun
    For short trips, average fuel consumption will never be fair.
    When you drive long distances, the magic of large savings numbers works))
  5. fuzzy1
    10,337
    I can't speak specifically to the Prius Prime, but for my RAV4 Prime, it is far too high to be HV-mode only. I've been assuming it is total miles (EV+HV) / total gallons, as it seems in the ballpark for that. Though haven't used this setting much.
    At 9600 miles, it is currently showing me a total MPG of 56.9, which far exceeds anything what it really achieves. I'm taking that to mean that it has driven very roughly about 2/3rds of its miles on gas, 1/3rd in EV.
    Between how it automatically goes into EV mode on downhills even when I have set HV mode, combined with how I often use HV for uphill and EV for downhill (including shallow slopes where it won't automatically go into EV), any such separation isn't going to make it comparable to how my former Prius expressed (HV) MPG. Both of this two behaviors (one of the car itself, the other my use of it), would tend to artificially shrink HV-MPG and inflate EV-miles/kWh.
  6. BiomedO1
    3,141
    1,664
    SacTown, Ca
    Yep; whenever I'm in the mountains I get 25+miles/KwH - you can't tell me that's accurate; considering I went up that same mountain earlier that day.
  7. fuzzy1
    10,337
    Descending mountains after a hike, I often see 99.9 miles/kWh, along with an increased EV range. I.e. regenerative braking has increased battery charge. But these readings apply to this trip only, since restarting car.
    After the road slope diminishes to the point the car won't glide anymore, or at least not fast enough to blend in with traffic, and the EV ranges drops to less than it had at restart, the miles/kWh plummets rapidly to single digits, then slowly to something reasonable or until EV range vanishes and it switches to HV.
  8. BiomedO1
    3,141
    1,664
    SacTown, Ca
    According to the Prius display table, it's a daily average, not a start-up trip average. That's the problem I have with it - if it's a trip average, there should be a tally on every startup. The 25+miles/KwH only makes sense if it was the trip down the mountain ONLY, not a daily tally as indicated by the OEM table.
    fuzzy1 likes this.
  9. fuzzy1
    10,337
    I haven't (at least yet) found such a choice in my RAV4, despite seeming to remember something similar somewhere in Owner's Manual. There is much I haven't yet absorbed or learned. The menu I've been using gives only two choices, single trip or overall, not daily or Trip A/B.
  10. BiomedO1
    3,141
    1,664
    SacTown, Ca
    You may not have that table, if it isn't a Rav4 Prime.
    I stumbled across mine, while flipping through screens on my Prime.
    Who need to read those stinking manuals...:sleep::whistle::notworthy::confused::(
  11. fuzzy1
    10,337
    My RAV4 is a Prime.
